So another indicator/hazard lights thread but really would appreciate your help please.
Indicator and hazard lights have stopped working. No click near the relay as well. Checked the fuse for hazard and it looked blown so chucked a new one on and yep it blew. Wondering what could cause this?
I can't find a new Niles IF356 flasher can anywhere and I've been to Repco, Autobarn and SCA and none of them have any flasher cans resembling this. Could it be a matter of the indicator globes need replacing?
Car is 1999 skyline gt
Edited by Teek
https://www.sau.com.au/forums/topic/479048-hazard-lights-fuse-keeps-blowing/
well the good news is that is likely to be straightforward....the hazard light positive is earthed somewhere...
first, unhook the flasher unit and replace the fuse, does it still blow? Yes, replace flasher, no, you have a wiring issue.  It's not impossible it is a globe but unlikely (you could pull out each globe in turn and see if that resolves the issue, don't forget the locally added side repeaters in the guard). Nissan (or amayama) should have the flasher, if not an aftermarket replacement is an option but you will need to connect the terminals correctly.
If it is a wiring issue you really need to start pulling things apart to access the wiring to find the problem, or if that doesn't sound like fun take it to an auto electrician.
Another possibility, as it is non turbo, is to just set it on fire and put the video on youtube, hopefully the advertising income will exceed the value of the car.
1 hour ago, Teek said:
but nah might just keep it for now
Boooooooooo, i wanted to see flames. ?
Keep us posted to what you find, take a bunch of pictures and upload them if you need help. :)
Hi,
So I've pulled the interior out a bit and have noticed that when I use the hazard switch I hear no click at all near the relay. I'm not really that electrical minded so am very confused. Does anyone have a wiring diagram for the hazards? I'm not able to find it anywhere for Skylines online
Do you guys recommend other steps that will help pin down?
Edited by Teek
  • 3 weeks later...
Quick update on this topic.
So I took it into an auto elec, they did their test and the bloke said when he pushes the hazard switch in very lightly the indicators work and no blown fuse. Told me I need a new hazard switch, okay cool easy done.
So I went in the car and about to drive off from the shop and tried the steps and nothing happened. So I grabbed the guy and said to show me what he did and yeahp nothing was happening. He played around and then all of a sudden everything started working again and it was all good. Indicators, hazards the whole lot. Turned the car off and then back on and then nothing, the relay can make a click sound but the indicators and hazard aren't working again???
Then I get home and turned the car off and back onto on and no click from the flasher can at all, nothing. Then few minutes later the flasher can clicks only when the hazards get pressed but not the indicators.
Does that seem like a wiring issue to you?
    • Im not entirely sure exactly what or where its leaking from, he started to pull the boots to swap to my new tie rods + ends and it just vomited fluid, so he closed em up up, swapped the rod ends to the old rods and let me know so I can figure a solution out, im guessing its all origional as as I passed 103k miles earlier this year im sure its just in need of a full overhual/rebuild anyways.    If i could just yank it off and be good it wouldn't be an issue to ship it out and wait for the turnaround but the guy I work with doesnt really have space to keep my car for a week or two at a time, would rather drop it off and have a replacement ready to drop in
    • What do you mean by "seals"? Internal hydraulic seals (ie, is it leaking PS fluid?) or the rack boots that close the rack onto the tie-rods? Because the former is a rebuild, and the latter is trivial that you or any nearby mechanic could do. Dunno about the cowl. Just buy what you think is required and get anything else you find/break afterwards. Wing? Dunno. Don't like R33s enough to pay attention to them. Mirror glass is just glass (on the surface that you want to polish). Go for it.
    • Hello! Long time lurker, been using the forums to address concerns and questions from afar for a while but I've struggled to find some answers so I guess its about time I made an account and formally asked some more knowledgeable people, since finding local skyline owners is hard (and shops that are knowledgeable or trustworthy to work on 'rare' cars are non existent out where im at, as skylines are quite uncommon to find in the wild around here). So the main 3 questions I have, 1: Steering rack has blown seals, well.. they kind of hold but they are not sealed properly anymore and as my R33 is my DD, i cant exactly rip the rack out and send it off or attempt to fix myself. As most refurb ones are around $1,100 or more shipped, and I have other things I need to work on around the car, I was seeking clarification on whether an S15 rack will more or less bolt right in, and whether a common mechanic could do any other required work to get it to fit. I ask, as I've found a supplier than can sell a manufactured as oem one for around 400, if not I'll likely order a used one from Jacks JDM, and take a risk on the seals there. The second question i have is that im replacing the front wiper cowl and have planned to buy 4 new clips and a new center clip but wasnt sure if there were any other clips that would also need to get replaced while I was at it. Given im sure any that are there now will simply break when I remove the old cowl... Last thing would be a fairly straight forward question, i think. If I manage (strong if, finding one has proven to be a pain) to find a R33 GTR spoiler/wing will it require much modification to bolt to a S2 R33 GTST? I've read the bolt patterns dont match but otherwise would bolt in, only options I have found with much luck is China stuff on ebay and carbonetics, which has a nice $650 shipping fee... so if anyone has any pointers where a US chap could locate one that would be great Random side question as well, the mirrors as I understand are mirror glass, and as im planning to polish my windows from water spots and surface scratches, i was hopeful cerium oxide would be fine for them too, as my research points to, but clarification is always nice. Any pointers would be appreciated, and while I have scoured the internet for answers if I missed a prior post somewhere that may answer these directly please point me towards it, as i must have simply missed it. I have seen a post here or there that has mentioned it, but I usually get 50-50 answers, or half answers... I dont have a lot of fab experience or mechanic experience, outside of hydraulic and pneumatic stuff I did in the military and with how hard it is to source stuff in the US, id rather not wing it and hemmoraghe money lol. Thanks guys! Sorry for the monumental first post haha
    • Yep, there's a very minor drift left that happens a few seconds after letting go of the steering wheel, but not enough to bother me. Enjoying the car still!
    • Got you mate. Check your email!
