I forgot to post this a few weeks ago.
My car was the volunteer car for JDM Accessories parts including their new wheels.
They're a fair but chunkier than stock but deffs worth the upgrade. Been running for over a month now and it's way nicer to use than stock.
Would recommend for the price.
This isn't a sale post. Just a recommendation incase you get the usual trash quality v36 wheel.
Mention  me when you purchase and he may even give you a discount :)
  • Like 2
https://www.sau.com.au/forums/topic/479110-v36-steering-wheel/
Do they have a better button bezel such that the paint doesn't scratch off the plastic so damn easily?
Also, does it feel weird at all with the flat bottom when doing full turns? I just can't help but think the discontinuity in the shape would feel a bit odd.
I've had  steering wheels and my friend has also has 2 and none of them have ever had this scratching issue.. i find it weird that its so "common" yet we've been through 4 and never once had the issue.
It doesn't come with those, you transplant those from the old wheel. Only takes 15 mins to do (super simple DIY)
You actually dont really notice it. It was weird the first 3 or 4 times but you easily adjust.
So I'll have to get mine wrapped then.
I haven't scratched mine but it did have a couple of scratches on it already. Maybe the previous owner didn't clip their fingernails regularly? :)
Care to message me the link to the supplier? I'm keen to know how much it'll cost me. Would be nice to have a fatter wheel.
The button Bezel on my 370 was pretty well scratched when I purchased the car. Purchased a new Bezel using Amayama. Better quality, will not scratch. Let me know if you want the part number.
I'm all ears, as I've been dubious about replacing it with another OEM one in case if it's the same materials/coatings. I was going to get mine wrapped.
Just checking, this is the bezel with cutouts for just the buttons on the left side for the stereo control, phone, back button and voice control, yeah?
Edited by The Max
Yeah the part you will get is definitely an upgrade in quality. In fact its nearly impossible to scratch I reckon.
Part Number ; COVER,PLASTIC Nissan 48463JK00A is without the buttons. A bit of google or put that part number into Amayama or Partsouq and you will find yours.
If you youtube steering wheel removal G37 or similar you will find a DYI on how to remove the steering wheel. IT takes about 15 mins with the right tools.
From memory you will need a 1/4 Socket and a T20H torx driver.
Good Luck.
Edited by SOO06E
If 48463JK00A is without the buttons, that will not be suitable for me, as I have buttons on the left side of the wheel and so the bezel needs to have the cutouts to accommodate them.
I think I'll just remove my wheel one day, disassemble it and look for the part number imprinted on it.
Lol i think he means its just the shroud without the buttons
As in you dont get the literal buttons. Cutout will still be there.
Also super easy to take off. Would be alot easier to take apart and Repaint/Wrap it yourself compared to buying a new one.
That's what I was hoping he meant, despite the fact I explicitly asked about the cutouts and not the actual (not literal) buttons themselves. Yes, I know I'm a grammar nazi but I just hate the overly misused word, "literal".
Anyway, the reason why I'm a little concerned is that when I looked up the data for that part number in two different drawings from Nissan's EPC sheets, the same part number appeared with the cutouts in one drawing (possibly hinting at cruise control on the right side) and no cutouts at all in another drawing (as well as no button cluster).
Given all that, you can see why with so much ambiguity from user and manufacturer alike, I'm a little dubious.
I have a spare one at home. when i get home ill get you the part number from it.
Legend. Thanks dude.
For anyone else who may be curious, Amayama seem to be the only guys carrying that particular part number. That being said, when I search based on my VIN, it claims to be a 48463-JK01A instead of 48463-JK00A. Luckily Amayama carries that one too. I already checked with Partsouq and they carry neither.
  • 7 months later...
  • 1 year later...
  • 5 weeks later...
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
