Hi,
i have an issue. When i turn on the lights before starting the car, all dashlights are working properly. As soon as I start it up and drive the lights behind the speedometer begin to flicker and turn off completely. Sometimes they come back on randomly. I also searched for a dimmer but aparently I can't find one in there.
Have anyone had such an issue before or can anyone help? I would like to prevent stripping out the interior :D
Thanks in advance :)
https://www.sau.com.au/forums/topic/479401-r33-gtr-speedometer-lights-flicker/
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
