Hi all,
Ive got a 2860r/rs small Garrett turbo on my rb25
it’s really responsive and have the z32, 550s and Powerfc to add on and turn. Hopefully to around 230rwkw
Im looking for a responsive package,
it has a split dump, does this look too restrictive to you? I think I have another dump somewhere, not sure if it will fit but it looked less restrictive to this.
The car makes around 7psi by 3k rpm in 2nd gear and current runs-around 12.5 psi max boost.
looking to run around 18psi boost, do you think this dump is ok?
thanks
ben
https://www.sau.com.au/forums/topic/479403-dump-pipe-r33gtst-for-230-240rwkw/
53 minutes ago, benl1981 said:
maybe I’ll just get the $170 JJR complete front/dump
That's the way to do it.
One word of caution is not to assume that the flanges are straight and the fitment perfect on any of these cheap dumps. They often require a little f**king about with.
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • BRUH, one of the biggest mistakes of my life..... and i've had plenty ;[)
