5 minutes ago, Rychiie said:
How would you describe the pedal feel? Is it really stiff/heavy?
Very light.  Light as or lighter than stock.
the issue with grabby clutches is trying to modulate them, and the fact they don’t want to modulate.
I've got one in an R33 GTST track car, with around 300 RWKW. Mine is the Xtreme "230mm twin plate race clutch with ceramic solid centre" - they have a few different twin plate options so not sure if this is the same one.
Pedal feel is good, and very light (certainly lighter than the single plate Xtreme ceramic puck that was in before, probably lighter than stock clutch). I don't find it hard to modulate, but I don't drive it on the street, only the track. Full noise starts are easy, no issues with it being too "grabby".
Like Ben, cost (around $1000 less than a Nismo) and local support were factors, plus the previous single plate Xtreme lasted a lot longer than I expected it to given the harsh environment & power level. I don't regret buying it.
  • Like 1
I am also considering the standard nismo super coppermix but im unsure of the actual rating. It states 471 KW however im not sure if they measure it from the flywheel or at the wheel.
What do you guys think?
Look just buy a clutch and try it, it won't be the last one you ever buy. But to answer the question again:
Nismo more driveable but would hold less power than the Xtreme twin. Xtreme twin less progressive, but you can't have your cake and eat it too. (compared to a standard organic full face clutch anyway.)
If that is your choice of clutches, personally I'd go with the xclutch on price, and ACS after sales support in Adelaide is really really good. They supplied me with all the ATS carbon triple clutches too/
  • Like 2
Um, the comp version of the Nismo is <$50 more and >100kW more. I know which one I would buy if I was looking at 400rwkW.
This is just me harping on a subject that I have little direct experience with though. So listen to the others ref the Extreme. I have an Extreme clutch behind my Neo, but it is a baby clutch, so not relevant. Except inasmuch as it did have a mechanical problem years after I bought it and Extreme covered something like half the replacement cost, even though it was well used. They are good people.
Look it's rwd, the right single will hold it, but a multiplate is obviously better for more surface area, therefore better torque holding.
Your overthinking it. Personally I'm not a fan of the Nismo clutches, had one once, never again. That's in launched GTRs, they just don't last repeated 7000+ rpm 4WD launches (waits for the Nismo coppermix brigade to chime in saying they are the best clutch ever).
Anyway sounds like you've got your mind made up so I don't really understand why you're still asking.
Buy one, try it, let us know what you think.
Um, when any clutch is engaged, how can it be noisy ? It's clamped so where is this noise you speak of coming from ? Do you mean disengaged (foot on clutch) and makes the signature Multi plate rattle, which all multiplates do ?
Sorry, pretty sure I didn't say engaged.
Released, as in not engaged, as in depressed. Sorry if my terms don't meet your approval - actually no I'm not, I couldn't give a f**k. I was pointing something out to someone who may or may not know how noisy a multiplate can be, not looking for a rude reply from you. If you know as much as you claim, you'd know what I meant by released - don't make up shit to make yourself look like an expert.
What's with the attitude ? Was not trying to be rude. Not making anything up, released was a shit term to use. I could use the term released as my foot not on the clutch, for example (clutch pedal is released). It was very clear what I meant, not what you meant. Having a go is not what I meant at all. I was not having a go, only clarifing. All multiplates generally do the rattle when depressed / disengaged mate, that's what I was getting at.
There are multiplates that don't rattle in the oem world, not sure in aftermarket.
It is a fair racket but at least you know why your car is making a crazy noise, people in the drive through not so much
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
