As stated in the title I'm having a problem with my engine stalling when coming to a stop. Sometimes my rpm will drop but find it's way back to 900 rpm, other times it will flat out die. Other symptoms include bogging/bucking at low rpm, low speed (1200-2500 1st and 2nd gear.) and noticeable misfire at idle. When I start the car AFR is 12-13.3, but as I let the idle sit it will slowly become more and more lean (17~19+). On throttle the AFR reaches 13-14 again, but once I get to a cruising speed it sits at 15-16 AFR.
Mods:
Freddy Front facing intake plenum, New gasket used when installed
90mm TB from eBay, New gasket used when installed
D585 LS coil conversion, using Wiring specialties plug n play harness
Maxpeedingrods stock replacement turbo, New genuine nissan t3 inlet gasket, and 6 bolt outlet gasket were used
Genuine and known good Z32 Maf, Wiring specialties plug n play harness
Walbro 255, Hardwired to battery, original signal wire used to trigger relay
ISR Fuel pressure Regulator
Wiring specialties RB25 to S14 Pro series Conversion Harness
Front Mount Intercooler
Tuned by RS-Enthalpy 2 years ago to support mods, problem started happening 3 months ago
No BOV
Some things I have checked/replaced:
Vac/Boost Leak test the intercooler pipes and core. Found leaks at the welds of the old Atmo vent BOV + a silicone coupler was split. Replaced coupler, replaced the whole pipe the bov was on with an untouched piece of 3" intercooler pipe
Replaced Walbro 255 with a new piece
Replaced Fuel filter, Z32 300zx TT Filter was used
Replaced injector O-rings as well as fuel rail to plenum O-rings, reinstalled with engine oil to grease o-rings so they dont get damaged on their way in
Raised Fuel pressure at FPR from 43 to 50 at idle
Optima Redtop Battery (AGM Battery - 770 Peak CCA) Tested and recharged
Removed IACV and Cleaned, reinstalled with new gasket and RTV
Replaced Narrowband O2 Sensor and Wideband O2 sensor
Cleaned engine grounds and Tested alternator to be in working order
Spark Plugs replaced with BKR7EIX gapped down to 0.8mm
Oil replaced with Royal Purple 5w-30, 4.8qt with Genuine nissan oil filter
Today I discovered a coolant leak from what I believe is the thermostat housing/waterneck. I will drain coolant and regasket that tonight althought I doubt that Is where my issue lies.
Believe me when I say I've used the search bar and google plenty before I post here. I'm desperately looking for some more suggestions
Edited by scumlort
https://www.sau.com.au/forums/topic/480028-rb25-s2-stalling-on-decel/
1 hour ago, GTSBoy said:
What ECU? How critical is TPS adjustment to the idle on that ECU?
its a z32 ecu with a chip tune. car has been ran on a dyno and tuned to run with the given mods. I am aware that when using this ecu one of the knock sensors is not connected to the ecu because of pinout differences.
34 minutes ago, Murray_Calavera said:
I'm guessing you have an aftermarket ECU of some sort. Is your fuel control set to closed loop?
What is the fuel trim doing once the car is warm at idle when the car is leaning out?
I'm honestly not sure how my fuel control is setup on this tune, I am unable to read the fuel trims with the consult as the tuner replaced a nistune chip that was installed for his chip and tuned the car.
I'm beginning to think I need to get my car retuned, maybe the file has potentially become corrupt
Edited by scumlort
f**k off the chip tune. It is 2020, not 1999.
Nistune is the superior solution, even with the difficulties associated with using a Z32 ECU on a vanilla RB25. Nistune has come a long long way to making that stuff work better in the last few years too, so would be worth your reconsideration.
Basically, this stall behaviour is the ECU not being able to control the engine speed when the throttle is closed. We normally point to the IACV because it is usually dirty/stuck. And just because you have cleaned does not prove that it is working. But the ECU can also struggle to know that it should be trying to maintain engine speed with the IACV if it doesn't know that the throttle is closed, hence my question about the TPS. I don;t know for sure about the Z32, but seeing as it is the same era as the R32, I would expect that the ECU wants to see a throttle closed SWITCH, not the analogue value (~0.45V) that is required on later ECUs (ie, RB25). So, I ask again, what TPS do you have on it?
  • Like 1
I honestly would have opted to keep the nistune board in it but I'm not capable of performing the tune myself. The TPS used is a stock R33 TPS with two plugs. Attached is a picture of an identical TPS. The TPS was set to read 0.49v with tb closed and 4.2 or something WOT. For reference the TPS is plugged into the left, the right is not connected
Edited by scumlort
I think that's your problem. Compare that with what I wrote in the post above. Then do some research as to what the Z32 ECU wants to see. If the ECU wants a switch, then with no closed throttle switch input to the ECU, there's no benefit to having the TPS set "correctly" to give the right voltage. The R32 ECU does not look at the TPS voltage at all - it only exists for the transmission controller. Hence why I suspect the Z32 is same same. You'd probably be better off with a Z32 TPS and whatever wiring change might be required to hook it up properly.
  • Like 1
38 minutes ago, GTSBoy said:
I looked. This page says the Z32 definitely has an idle switch
https://conceptzperformance.com/wiki/index.php/Throttle_Position_Sensor
Thank you for finding that page for me, I will look into finding a Z32 Ecu pinout diagram and wire the second connection for the hard idle switch to the ecu. What still confuses me is that once the car was tuned, it would come back to idle perfectly fine for a solid year and a half. Only recently did it begin to stall under decel. This leads me to believe that this hard idle switch being open wouldn't be my only problem and something else is left unresolved. When the car was tuned I had the atmospheric vent blow off valve so i'm positive some fuel was added to compensate and keep the car from stalling. In an attempt to rectify the issue i'm having I removed the BOV altogether. I would assume this would produce a rich condition but my AFR is very lean.
You have R33 TPS. Does it even have the idle switch? If not, you'd need an R32/Z32 TPS.
You can't really interpret AFRs when an engine is stalling. When the fuel isn't getting burnt, analysing the exhaust gas is a waste of time.
As for the then and now scenarios - things change. Leaks develop. Injectors get dirty. Etc. That's why engines have adaptive shit on them (like the IACV and the ECU given the idle switch so it knows when to use it) - to get them past these changes and keep working. When you "tune" an engine to suit a very specific set of conditions (BOV/no BOV, certain level of cleanliness of the TB/IACV, etc) you leave it exposed to changes in those base assumptions. You either attempt to maintain the conditions of those assumptions or you prepare to compensate (retune) for them as the changes mount up.
  • Like 1
In general you are better to retain the stock TB when going FF plenum. You need an adapter plate but then the TPS etc is all stock. They are good for at least 500hp maybe more. If you still have it consider returning to stock.
    • I know why it happened and I’m embarrassed to say but I was testing the polarity of one of the led bulb to see which side was positive with a 12v battery and that’s when it decided to fry hoping I didn’t damage anything else
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
