40 minutes ago, admS15 said:
f**k man, you have a real sickness. Et streets on 16's or even 15's will grip much betterer. Need that side wall big profile energy. Not sure if will look more or less bogan though.
I'm going 17" because I want to have matching rims, and 17" was the smallest size the FR1's come in, so comprises were made for the Bogan-ness of the FR1 life, it isn't optimal, but meh, it's going to be good enough for what I want
My old GTS-t Skyline made similar top end power to the Commodore, and got a 11.09 on ancient worn out 255/50 16 Mickey Thompson streets, and they hooked pretty good on the street in the dry as well, which is handy with a RWD car
Plus the Mrs will never pick the change, which is always a bonus
As for looking more or less bogan, impossible, the car is a old red commodore with gold FR1 Simmons, and I'm a old balding white guy with tattoos, so  I'm pretty sure I got bogan covered, much to my Mrs anguish
  • Haha 2
I has rubbers, build date was 0822, fresh stock, which is nice
Ordered the rims, they're getting machined for offset, I pick them up and get the tyres fitted tomorrow
Typically it has started to rain again so Wednesday night drags probably isn't on the cards
  • Like 2
Almost the ultimate bogan chariot but needs 2 doors for that title.
Get onto a suspension shop about a decent rear setup. That tyre can work with the right setup.
4l80 or 6l80 an option for you? t400 is getting hard to find now and decent internals
https://www.facebook.com/BrinksPerformance/posts/624930669420914
My current suspension will do for the 2 or 3 trips to the drags I do a year, the car is just a street cruiser with visions of grandeur
My old R33 only ever ran Bilsteins and kings and hooked OK on the Mickeys
As for the gearbox, there's a few options, but really, unless/until the 4l60e goes bang in a big way there's no hurry
Currently the trans is rated/guaranteed to 600hp at the motor, which it is roughly at now, Craigs have stated that it will still be fine though as they add in a fudge factor, they said it should be good for about 700hp, or 450kwatw but, that would void warranty and be on limited time
Fark, I keep blowing the main 60 amp fusible link
No reds at all, I just parked the car after returning from a drive, then tried to move it to wash off some dirt and nothing, no power at the ignition, no reds, no horn, no central locking,  no immobiliser, found the main 60 amp fusible link blown, so replaced it with the 60 amp ABS one to see what was going on, which brought the reds up, until I tried to start it, which then blew that fuse as well 😒
There's a short somewhere, I'll  need to jack up the car and look for the short, I'm hoping it's an easy "starter motor wiring meets exhaust headers" type of thing
Stupid cars 🚗 😒 🙄 😑 😤 😐 🤣
  • Sad 1
That sucks, I guess she doesn't want you to put those new tyres on her
FWIW, it won't be the starter motor via a 60A fuse, way too small, but headers (and anything else you've modified, which is almost everything now :p) would be the place to start.
Multimeter in the Fuse socket will probably confirm continuity to ground, and one option is to disconnect battery +, put 60A fuse back in and then check the regular fuses one by one to narrow down which specific circuit has the issue (I'm assuming the 60A fuse is in serial with the individual fuses like in sykline)
Yeah, but if it's enough current to pop the 60A fuse, it really shouldn't blow one of the smaller fuses downstream. I would presume that there's a significant short in the wiring between the 60A fuse and any other fuses downstream. Melted insulation is the obvious thing to look for.
But yes, pulling any and all downstream fuses, then probing in the 60A fuse socket looking for earth would be the best way to start. Hot tip - there shouldn't be a nice path to earth there!
1 hour ago, Duncan said:
It never ends
But it is expected with old or modified stuff
And it's not like it spends it's time in a garage coming out on sunny Sundays, the car is regularly used and abused, rain, hail or shine...well, rain and shine, I always keep an eye on the BOM for work, the car and bike is typically hidden away during major storms
I expect things to happen, nothing lasts forever,  and shit breaks when you lean on them, but, I'm happy enough because the old girl gives alot of joy, the car is fun as well..............😜
As for the new starter, I've still got some heat sheild left over from the job I did on the headers, I might look at making a cover like this thing > DCI-XT-5000-STR.thumb.jpg.836ec6b8b1a907e4a6410811e19de383.jpg
  • Like 1
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
