Tailshaft bushes and centre bearing was fine, torqued up all suspension and steering nuts and bolts under the car
Need to go to the drags again and see how it goes at higher than Hwy speeds now (over 80mph)
I will get all my wheels rebalanced first
Hopefully around mid December
  • Like 1
So, after alot of googling the vibration "may" be coming from the transmission
"Apparently" vibrations in a 4l60e can happen at higher speeds if the line pressure isn't right, which is what's happing
So, as the trans was due for a service in Jan 23 anyway, it has been booked in for the service at Craigs Automatics, while it's there they said they will look at the tune and see if they can "page up" the line pressure a bit in the old slush box
Next run at WSID is hopefully 21 Dec 22
  • Like 1
Purchased one of those brake bleeders that connects to my air compressor....... "where have you been all my life"
After putting it up on stands and removing the wheels a full brake flush took no more than 5 minutes, nice
Then....whilst it was up there.....
Ended up going OCD and gave at undercarriage a full power wash, sprayed everything with silicone spray, and then wiped it all down, now all the bits that you cannot see look so shiny and purdy....LOL
The interior then copped a full detail with the bissell spot cleaner and steamer, the interior looked pretty good before I started, but the manky water that the bissell sucked out proved other wise, but it has been 12 months since the bissell last seen any action inside the car
The engine bay is next, well tomorrow, for a detail, followed by exterior washing and waxing all ready for a cruise down to Goulburn on Thursday for my daughters attestation at the police academy on Friday
My daughter has asked me to wear my service dress, and Jackie has grabbed a fancy outfit for the occasion, the car will be on point like it is on a military style "boots and saddle parade".....so.....
Weather warning: you just know it is going to be pissing down in the Southern Tablelands on Thursday and Friday, and they will probably want me to park in some unsealed carpark....LOL
  • Like 1
Which model of the bissell steam cleaner are you using? Is it one of those you can get at supercheapauto?
I quite like the idea of doing that to get 20+ years of gunk out of the carpets in the car. Have been holding off though as I wasn't sure whether the "cheapy" ones would be any good.
Yeap, that's the one
I use it around the house on small spills and stuff as well
If you haven't "wet vacced" the seats or carpet for 20 years you will definitely need to give it a few goes
Be prepared to change water that looks like diarrhoea
  • Thanks 1
Haha, see how it goes! Good to know that it works out alright. Don't know if it has been that long, but I wouldn't be surprised. The cabin filters certainly looked like it when I replaced them.
Will keep an eye on supercheapauto and wait for a sale.
  • Like 1
I have a bissel thingy but yet to actually try it on car, or carpets. Not really sure why as I recently cleaned the car.. and carpets. Could use it on door inserts too. Pretty easy to remove the rear seat out of the car too. In short, I have been lazy.
Thankyou for mentioning this vaccum brake bleeder thing, now that I know that exists my life is 4% improved.
  • Haha 1
Got the transmission serviced today at Craigs and talked about the vibration, found what is causing my vibration at speed, the Tuff mounts
The ones I have have the red poly in them, so pretty firm, under load at speeds over 100 mph harmonics from the engine are transferring the engine harmonics through the K frame sending the vibration to to the steering rack and body
They recommend that I go back to rubber if I want to get rid of it, they also said that it isn't a issue, apart from the NVH, as I need lower engine mounts that the OEM rubber ones for bonnet clearance that unfortunately isn't a option
It is apparently a common issue with hard poly and solid engine mounts in some cars, he had red Tuff mounts in his 1200hp Skyline and had the same issue, same same for some of the drag cars he works on
Tuff mounts do a black poly that is softer and would be a little better but as it only happens at the drags, from 100mph - 124 mph, I probably won't swap them out
I other news we want down to Goulburn to watch my daughters Assentation, parked up in the police academy and proceeded to have "all" of the police checking out the car, luckly the all agreed it was a nice build, a little loud, but nothing that would cause them concern
I did feel like a rabbit in a spot light for a while though
  • Like 2
lol driving into the lion's den!
sounds like you should have bought a nissan v8 not a holden. Cima came with active engine mounts so as not to trouble Japanese execs with such things.
  • Haha 1
The standard holden mounts were fine, until I put thermal spacers under the blower and the bonnet wouldn't close
The clearance issue was temporarily fixed with the reverse cowl bonnet, but, it took 2 weeks before I hated the look of it
Meh, first world modification problems
And yes, "driving into the loins den" is exactly how it felt...🤣
1 hour ago, GTSBoy said:
Is that because they're a bunch of pricks?
LOL, where's spell check when you need it
As for pricks, yeah nah, I've only been hassled by the police when I've done something stupid, getting pinned for an illegally modified car for example is a fair cop in my opinion
I've got alot of cop mates, and my daughter is now one, they do a hard thankless job, and in reality, if you don't do stupid stuff, or blatantly break the law they leave you alone
There job is to enforce the law, whether or not I agree with the laws means nothing
They are the ones who stand between you and the crazy taking the fire
RIP to the 2 young QLD cops that were set up and assassinated by mentally deficient lunatics
RIP to the neighbour who went to see if the mentally deficient lunatics needed help, only to be killed for his neighbourly  good deed
Police are like soldiers, nobody loves them until the enemy is at the gate
  • Like 2
45 minutes ago, GTSBoy said:
Yeah, I was aware of the daughter and other cop friend link. I was sticking it to you for your possible Freudian slip!
Yeah, it's cool man, I've seen and heard about the stuff they go through on a nearly daily basis, first responders see the worst of people, and people at their worst time, like MVA, murders, assaults, suicides and the like
I've seen some pretty horrific stuff, and been in the odd sticky predicament, but nothing like the saturation they deal with, like ambos and fire fighters, it is a real common occurrence and a head f#ck
I am sometimes to quick to judge and go partial retard  when people go on about the police, sometimes a joke triggers me
Meh, love you long time
  • Like 1
Yep. I am of similar thinking.
Imagine how shit or off the rails your day has gone for you to dial 000 for Fire, Ambo, or Police.
That's their entire work day.
Every single day.
  • Like 1
Finally stuck the new head lights in
Just need to go to the "big warehouse" at work, turn off the lights in the warehouse and align them better
They are level, but probably not at the correct height or centred correctly
  • Like 1
The Mrs commented that there was a little drone on the Hwy in cruise doing 110, I never noticed it, but meh, I got the local exhaust shop that built my exhaust to throw in a resonator
Space was limited, so they fabricated a custom little 12" x 4" in and out, round resonator with a 5" body that fits like a glove
I'll need to wait till we go for a cruise this weekend and see if she even notices, but, it has smoothed out the "rage" from the exhaust at WOT, it isn't exactly quiter, it has just lowered the tone down a bit, I actually think it sounds better now
And it didn't cost a thing, winning....I love free stuff
  • Like 1
Full wash, wax and detail, so you know it's going to rain this weekend when me and the Mrs go for a cruise to Robertson pie shop
Also removed the sub, amp and associated wiring from the boot of the car
The aftermarket Pioneer head unit and speakers are sweet anyway, the sub just made stuff rattle, I forgot how much room for activities the boots in these things have
I've also decided to further investigate the vibration I get at the drags over 100 mph, it will be getting the driveshaft reconditioned and rebalanced with new uni joints, center bearing and couplings
In other Mrs related news, the car is still to loud for her liking when starting it in the morning ( #because the neighbours), "sigh", so I am contemplating getting a 4" Varex oval muffler for the rear, wired im to a momentary switch, when it is closed I'm hoping she stops breaking my balls, when it is open, I assume it will probably be louder
Hardy Spicer in Moorebank did a reco on my tailshaft so it is now back to new....OEM spec IRT couplings, uni's and centre bearing (that puppy was trashed), it is all balanced up and within specs........soooo......
I'm going to WSID tomorrow to see how it likes some tailshaft speed
They said due to the power I'm making the front and rear OEM style couplings probably won't last to long if I'm launching it hard with drag radials, and if I'm doing alot of high tailshaft speed runs (read: at the big end at the drags) the centre bearing will also not be enjoying life
A fancy new 3" 2 piece tailshaft with super dooper big uni's and some special centre bearing that can cope with all of the rpm's and all of the killerwaps is apparently only $2.5k away, so as my max rpm is only 6k rpm, that is an over engineered option available for when I chew out my new OEM spec one
Also purchased a killer wickerwork picnic basket for when we go on country adventures, this will work well with my 12v fridge to keep all the fruits, cheeses, sangas and vino chilled
  • Like 2
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
    • OK, if it idles at 1000+ with the AAC, its not an idle airflow problem. The cold start valve just gives extra air when the engine is cold, but you have enough air without it to idle at 1000. I think you are back to a fuel problem, sorry. Can you see the fuel pressure staying constant or does it drop as the revs drop to a stall?
