2 hours ago, GTSBoy said:
Adrenalin glands, or adrenaline glans?
Fixed your post, spell check must have got you
LOL, well spotted by you, not the editor working for Holden
9 hours ago, GTSBoy said:
No, it was a joke. They were "correct". I just feel that knob end is possibly closer to the target audience! 😛
You calling me a "Knob end"....
LOL
#kinkstaah you good looking rooster
So, RaceTCS is installed and working as advertised, just to good, or, basically not set up right yet
First tyres tested were the 255/40 17 RS4's
The % of slip settings and the Max % fuel cut, all 6 set at 95% fuel cut are to aggressive for my driving "style" of mashing the pedal everywhere I go
Setting 1: min 3% Max 27% , nope even on a little stab it cuts hard
Setting 2: min 6% Max 31%, nope again
Setting 3: min 9% Max 34% still nope
Setting 4: min 12% Max 37%
Setting 5: min 15% Max 40%, bit better, but still aggressive
Setting 6: min 20% Max 50%, noticeably better but still cut aggressively with more throttle
Can you have a squizz at the pic to give me some pointers?
What sort of settings do you run
Any tips in setting the min and Max for each Setting, or what % of fuel cut, I assume 95% fuel cut basically turns a V8 into a 1 cylinder, from my uneducated mind....shouldn't it be around 12.5%, which, again from the jumbled mind of Mark, should only drop 2 cylinders?
Disclaimer: I just did math in my head with the help of my fingers
Cheers :91_thumbsup:
From: http://www.racetcs.com/files/RaceTCS V2 User manual.pdf
From: http://www.racetcs.com/files/RaceTCS V3 User manual.pdf
There's two versions, unsure if the actual hardware you have is different or whether you just have the older software.
The actual PDF describes what the functions do pretty well, so I'd just be retyping it. Your settings ARE different to the default (you've got a mix of V3 and V2 defaults?) which they put a disclaimer in saying that most people don't need to change them.
Interestingly, unlike the Racelogic which gives you actual misfire patterns to program in, the RaceTCS looks to use PID's (like an electronic boost controller) to program its interference with your powah.
Step 1 would be to go for a drive, log the wheel speeds, make sure they are actually reporting correctly (unsure if you have done this, it says in the documentation to do this too).
Step 0 would be to make sure you have the default settings for the piece of hardware you have, and the piece of software you have. From what I can read your assumption is correct, that 95% max cut means it'll cut at most, 95% of cylinder ignition events which as you would know makes the car run pretty sloppy lol.
I suspect what is happening is the PID settings are incorrect and the system is cutting 95% of power when it should be trying to cut 5% of power, or a wheel speed sensor is doing weird things, and you have a scenario where you have three wheel speed sensors reading 40kmh, and one wheel speed sensor reading 197kmh, or 0kmh, and you need to confirm this isn't happening first :D, and make sure EACH WHEEL IS ACTUALLY THE CORRECT WHEEL. The easiest way to do that is to go around a roundabout and make sure your outer wheels are reading a couple of kmh higher than your inner wheels. If you're breaking traction and the system thinks it's your front left doing a skid then everything is going to be quite upset.
  • Like 2
I'll take the car out this arvo for some logs
I sent a email this morning to the RaceTCS website and they got back already
They require a file of my configurator to see what version and some logs
Although I believe I do have the latest firmware thingie
Arrrrggggg....computa stuff
It actually looks pretty simple to pull logs though
Hopefully it as simple as sending logs then uploading the changes they recommend
It's not so much firmware. There's two entire versions of the software. Perhaps (?) there is versions of the hardware too. Your numbers don't match the defaults that are in either version. You gotta start from a correct baseline before doing anything else :D
  • Like 1
I've sent a file of the configurator and a couple of logs to Jacek from RaceTCS
He said with those files he can sort it all out
Fingers crossed
I am sure he will man, but having the menu structure from the V2 app with V3 settings jammed in there should be fun. Obviously I'm curious to see how this all turns out. How did the logs look? Are your wheels following the laws of physics?
Sortware and stuff is fine apparently
I need to reset the "pid" and change the voltage in the configurator to start with
He want me to turn off the TC and log doing a skid to start with
There was an area he wants to look at where the wheel speed went up, but not the revs
Once we get the that checked off there will be more logged pulls with different settings on the TC
Then, test and adjust
The support I'm getting from Jacek at RaceTCS is really good, typically same day reply
Cheers
  • Like 1
11 hours ago, Liz said:
Nice car, Mark!!
My dad has one of these, it’s a lot of fun! He’s had it for 20 years and cannot bring himself to sell it.
Maaaaate, they are great thing for cruising around, so comfortable, and having 5 usable seats and a big boot is great, plus V8 noises sound cool to my old ears
Whilst they are not everyone's cup of tea, and I only really got it as something as a "in-between fun cars thing", now, a few years later, I have no intention of getting rid of it
I enjoy looking at 100x more than the 2015 WRX I had, but I do miss my 86 that I drove into a guard rail, backwards, at speed
Not saying I'm not looking for something new, but, when I try to justify the change, nothing else really ticks the boxes like the Bogan Cruise Ship does
I think I would actually sell my Harley before the VX
I am picking up the old (2008) Yaris YRS I got for my daughter when her new Cerato GT turns up, the Yaris will be my local daily hack, the V8 does love fuel, and I hate parking the VX at the shops or driving it in the rain
Updated Configurator has been sent by RaceTCS
I'll upload it in the morning and "test" it tomorrow
I thanked Jacek for his help and time, he said no issue and to keep sending logs till it's perfected
Tomorrows conversation;
Police: "I've pulled you over because you took off really fast and did a skid"
Me: "Yeah Nah, it's all right, RaceTCS told me to do it" :10_wink:
  • Like 2
Updated Configurator was dropped in and launching was done
Settings were better, it wasn't "horrible" at WOT in 1st and 2nd, but still a bit aggressive and noticeable
I logged a setting 6 on the street tyres and a pull from stopped through 1st, 2nd into 3rd, setting 6 lets most amount of slip in the current slip settings, and sent it off to Jacek
I did also tell him I'm happy to lay "some" rubber in 1st and 2nd at WOT in setting 6 on the street tyres, currently I cannot really feel any wheel spin that would really concern me as the TC kicks in real quick
When I'm happy with they street tyre settings I will see how it goes with drag radials at the "strip"
The plan, if I haven't already mentioned it already, (blame my little fun sized stroke I had 2 years ago) is settings 4-5-6 will be for street tyres, settings 1-2-3 for the drag radials
So far so good, test and adjust, test and adjust
Shiny shiny
  • Like 6
Depends on what your traces show obviously, but in my application with 10% slip, you literally cannot feel any traction loss at all. There's no intervention feeling, and you don't feel like you've lost it, even though technically you are doing a skid. It does feel like you somehow don't have as much power, but that's because you don't have as much tyre as you could :D
  • Like 1
New settings have already arrived :91_thumbsup:
Min and Max slip settings were raised a bit and Max fuel cut was lowered a bit in all settings
I'll load them in and do some testing tomorrow
I am really happy with the RaceTCS and the support I'm getting
  • Like 2
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
