2 hours ago, GTSBoy said:
Adrenalin glands, or adrenaline glans?
Fixed your post, spell check must have got you
LOL, well spotted by you, not the editor working for Holden
9 hours ago, GTSBoy said:
No, it was a joke. They were "correct". I just feel that knob end is possibly closer to the target audience! 😛
You calling me a "Knob end"....
LOL
#kinkstaah you good looking rooster
So, RaceTCS is installed and working as advertised, just to good, or, basically not set up right yet
First tyres tested were the 255/40 17 RS4's
The % of slip settings and the Max % fuel cut, all 6 set at 95% fuel cut are to aggressive for my driving "style" of mashing the pedal everywhere I go
Setting 1: min 3% Max 27% , nope even on a little stab it cuts hard
Setting 2: min 6% Max 31%, nope again
Setting 3: min 9% Max 34% still nope
Setting 4: min 12% Max 37%
Setting 5: min 15% Max 40%, bit better, but still aggressive
Setting 6: min 20% Max 50%, noticeably better but still cut aggressively with more throttle
Can you have a squizz at the pic to give me some pointers?
What sort of settings do you run
Any tips in setting the min and Max for each Setting, or what % of fuel cut, I assume 95% fuel cut basically turns a V8 into a 1 cylinder, from my uneducated mind....shouldn't it be around 12.5%, which, again from the jumbled mind of Mark, should only drop 2 cylinders?
Disclaimer: I just did math in my head with the help of my fingers
Cheers :91_thumbsup:
From: http://www.racetcs.com/files/RaceTCS V2 User manual.pdf
From: http://www.racetcs.com/files/RaceTCS V3 User manual.pdf
There's two versions, unsure if the actual hardware you have is different or whether you just have the older software.
The actual PDF describes what the functions do pretty well, so I'd just be retyping it. Your settings ARE different to the default (you've got a mix of V3 and V2 defaults?) which they put a disclaimer in saying that most people don't need to change them.
Interestingly, unlike the Racelogic which gives you actual misfire patterns to program in, the RaceTCS looks to use PID's (like an electronic boost controller) to program its interference with your powah.
Step 1 would be to go for a drive, log the wheel speeds, make sure they are actually reporting correctly (unsure if you have done this, it says in the documentation to do this too).
Step 0 would be to make sure you have the default settings for the piece of hardware you have, and the piece of software you have. From what I can read your assumption is correct, that 95% max cut means it'll cut at most, 95% of cylinder ignition events which as you would know makes the car run pretty sloppy lol.
I suspect what is happening is the PID settings are incorrect and the system is cutting 95% of power when it should be trying to cut 5% of power, or a wheel speed sensor is doing weird things, and you have a scenario where you have three wheel speed sensors reading 40kmh, and one wheel speed sensor reading 197kmh, or 0kmh, and you need to confirm this isn't happening first :D, and make sure EACH WHEEL IS ACTUALLY THE CORRECT WHEEL. The easiest way to do that is to go around a roundabout and make sure your outer wheels are reading a couple of kmh higher than your inner wheels. If you're breaking traction and the system thinks it's your front left doing a skid then everything is going to be quite upset.
  • Like 2
I'll take the car out this arvo for some logs
I sent a email this morning to the RaceTCS website and they got back already
They require a file of my configurator to see what version and some logs
Although I believe I do have the latest firmware thingie
Arrrrggggg....computa stuff
It actually looks pretty simple to pull logs though
Hopefully it as simple as sending logs then uploading the changes they recommend
It's not so much firmware. There's two entire versions of the software. Perhaps (?) there is versions of the hardware too. Your numbers don't match the defaults that are in either version. You gotta start from a correct baseline before doing anything else :D
  • Like 1
I've sent a file of the configurator and a couple of logs to Jacek from RaceTCS
He said with those files he can sort it all out
Fingers crossed
I am sure he will man, but having the menu structure from the V2 app with V3 settings jammed in there should be fun. Obviously I'm curious to see how this all turns out. How did the logs look? Are your wheels following the laws of physics?
Sortware and stuff is fine apparently
I need to reset the "pid" and change the voltage in the configurator to start with
He want me to turn off the TC and log doing a skid to start with
There was an area he wants to look at where the wheel speed went up, but not the revs
Once we get the that checked off there will be more logged pulls with different settings on the TC
Then, test and adjust
The support I'm getting from Jacek at RaceTCS is really good, typically same day reply
Cheers
  • Like 1
11 hours ago, Liz said:
Nice car, Mark!!
My dad has one of these, it’s a lot of fun! He’s had it for 20 years and cannot bring himself to sell it.
Maaaaate, they are great thing for cruising around, so comfortable, and having 5 usable seats and a big boot is great, plus V8 noises sound cool to my old ears
Whilst they are not everyone's cup of tea, and I only really got it as something as a "in-between fun cars thing", now, a few years later, I have no intention of getting rid of it
I enjoy looking at 100x more than the 2015 WRX I had, but I do miss my 86 that I drove into a guard rail, backwards, at speed
Not saying I'm not looking for something new, but, when I try to justify the change, nothing else really ticks the boxes like the Bogan Cruise Ship does
I think I would actually sell my Harley before the VX
I am picking up the old (2008) Yaris YRS I got for my daughter when her new Cerato GT turns up, the Yaris will be my local daily hack, the V8 does love fuel, and I hate parking the VX at the shops or driving it in the rain
Updated Configurator has been sent by RaceTCS
I'll upload it in the morning and "test" it tomorrow
I thanked Jacek for his help and time, he said no issue and to keep sending logs till it's perfected
Tomorrows conversation;
Police: "I've pulled you over because you took off really fast and did a skid"
Me: "Yeah Nah, it's all right, RaceTCS told me to do it" :10_wink:
  • Like 2
Updated Configurator was dropped in and launching was done
Settings were better, it wasn't "horrible" at WOT in 1st and 2nd, but still a bit aggressive and noticeable
I logged a setting 6 on the street tyres and a pull from stopped through 1st, 2nd into 3rd, setting 6 lets most amount of slip in the current slip settings, and sent it off to Jacek
I did also tell him I'm happy to lay "some" rubber in 1st and 2nd at WOT in setting 6 on the street tyres, currently I cannot really feel any wheel spin that would really concern me as the TC kicks in real quick
When I'm happy with they street tyre settings I will see how it goes with drag radials at the "strip"
The plan, if I haven't already mentioned it already, (blame my little fun sized stroke I had 2 years ago) is settings 4-5-6 will be for street tyres, settings 1-2-3 for the drag radials
So far so good, test and adjust, test and adjust
Shiny shiny
  • Like 6
Depends on what your traces show obviously, but in my application with 10% slip, you literally cannot feel any traction loss at all. There's no intervention feeling, and you don't feel like you've lost it, even though technically you are doing a skid. It does feel like you somehow don't have as much power, but that's because you don't have as much tyre as you could :D
  • Like 1
New settings have already arrived :91_thumbsup:
Min and Max slip settings were raised a bit and Max fuel cut was lowered a bit in all settings
I'll load them in and do some testing tomorrow
I am really happy with the RaceTCS and the support I'm getting
  • Like 2
    • I am getting the same issue. Did you resolve it? I just got it after installing my new super coppermix and literally the same issue, new fork, new 18mm carrier, release bearing that came with the kit and replicated the exact same sound.
    • If you like - I have the STL files so I can email em. There's a couple of gotchas (i.e the holes are not threaded so you might need/will need) to utilize some M3 melt-in threads for some of the points. However if you want to be super accurate, and are willing to remove your calipers and your SHOCKS it's a really good tool. You also might need to scale the part that measures the tyre width a bit wider. It defaults to a 7.5in tyre and I mean who is running that. Luckily with the magic of CAD this is very easy to rescale.
    • jeebus. glad you weren't under it while performing the stunt. Also thanks for the link to the wheel measurer, exactly what I needed
    • In the older stuff there were very significant differences 2wd to 4wd, for example Stagea had strut front end for 2wd and double wishbone for 4wd so it was not minor to swap. From poking around the 2wd v37, it *looks* like it might be more possible; some of the parts specifically have "2wd" stamped on them which suggests the platforms are more similar. You'd still want to start with a 4wd half cut to swap stuff from though. I'd suggest if you don't have a tune on the ECU you don't really need one on the trans either. Throttle mapping is in the ECU side (and you can always use a Roar Pedal if you want the throttle to actually respond to your foot), and really if you are happy with the stock power you probably accept the stock trans behaviour too....its all made to be "sporty" not racey.
    • So, updates. I have not washed the car since it came back from Tassie. I've driven it around a bit but not got around to actually sorting it out. I DID raise it because I cracked the rear bar leaving a hotel which was very distressing. Interestingly, the car drives more compliant now that it's raised a fair bit (5mm front, 15mm rear). Also noticed that my FR height was 10mm lower than FL. So that's now sorted out, too. I also bought this and had it printed: https://www.etsy.com/au/listing/1576422240/wheel-and-tire-fitment-tool-universal?ref=shop_home_feat_1&dd=1&logging_key=08f604d9fa4cc383550ba985e6ac85cd5cac7fbb%3A1576422240 Now, if I was smart I would have taken my brake calipers off to actually use this correctly but it was evident enough to me that in the region where the caliper was... there was nothing to hit suspension/guard/arm wise. So I'm going with "it'll be fine" after using the tool to hopefully very precisely measure the wheel clearance. Also while doing this, I had the very VERY bad idea of jacking one of the wheels/suspension arms up while the rest of the car was on jack stands. I did this to see how the arm would travel. This all was well and good until the car slid off the stands and went through a fence. So don't do that. Incredibly nobody was hurt and there was only minor damage to the rear bumper as the car didn't have far to slide, and had 3-4 wheels on it. The only damage turned out to be the fence itself which was easy to fix, and a little bit of damage to the fibreglass rear bumper trim. I had already planned to try a touch up paint kit to fix the time I drove into my garage door to see if it'd help in the interim before I get it fixed properly. I used the Dr Colorchip kit after looking online and seeing everyone talking about it. Yes it's made for chips and not huge broken missing pieces and I'll be 500% recommending it for stone chips after using it for stupid things like me. This took about ... 10 minutes and looking at the half assed photo the 30 second job I did on the bumper corner was almost perfect just by using the tiny little brush and painting it in. The sealact stuff to remove over-painting is really useful, so if/when I do it again I'll likely slather the touch up paint well over it and then clean it up with the cleaning solution. The wheels should arrive in a couple of weeks. I am still kinda confident after doing a stupid amount of measuring (and borrowing a set of 18x10.5+15) that they will not fit because I overlooked something, somehow and flew too close to the sun. ALSO R34 GTR guard liners do not fit on a GTT. I bought the undertray brake duct guides and had the wonderful problem of them not fitting my intake, my oil cooler and the liners themselves were even worse. Attempting to fit them won't work in general - You would have to cut them up as another poster mentioned as the bodywork is different on the GTT. At least I can try to resell them. So instead of cutting those up, I cut up my old already-cut-up GTT liners and extended them by using some PP plastic and drilling some 8mm holes for some nissan clips for the 'extra' bit. Because I was happy to cut them I was able to mount them pretty damn forward so I now have some semblance of guard liners, and the brake vents seal the bumper from the bottom. It sort-of-looks like this, to give some idea - If you look at the GTR and then the GTT this is when I realised that I needed to seriously measure as the inside of the rim area is entirely, entirely, entirely different and could not take any internet measurements for granted.
