14 hours ago, GTSBoy said:
It was probably pinging its tits off.
It is probably still lean. You have been warned.
It wasn't at all. No pinging noise whatsoever which I would have expected to hear also. I think the ecu was stopping it by limiting the power and hence the sudden reduction in power when boost went over 5 psi. Thanks for the warning mate but it's not an expensive car so I'm not overly concerned, nor should you be ?. However I will definitely check the fueling when it is allowed to get out and on to a dyno. But I think it was just the timing issue tbh, 12 degrees wrong is a lot and the car now drives fine. Now if it was one of my more expensive cars I would be more worried. I appreciate people trying to help. On this occasion no one got the diagnosis right, no one said check the timing,  hey ho it's all a learning curve I guess. It might help someone else.
Stay safe.
Edited by Tonyr33gtst
I also have this ecu. Does your car have all the supporting mods for the chipped ECU? This is taken from bells:
RB Rebuild (Bells Auto Services) Stage 1 V2 ECU for Skyline R33 GTST.
New Stage 1 R33 GTST ECU V2 remap with improved fuel and ignition tables. Limiter increased to 7400 and a few other tweaks. Will give slightly more power and response over older versions.
Modifications required are:
- Front Mount Intercooler
- Full Exhaust System
- Decat
- Induction Kit
- Boost increase to 0.85bar
- Shell V-Power 98+ Octane fuel
Power can be expected upto 330bhp depending on engine condition and correct setup of ignition timing.
  • 4 years later...
On 4/7/2020 at 11:12 PM, GTSBoy said:
1 bar is 14.5 psi is 760 mm of mercury. The stock gauge is marked in hundreds of mm of mercury. So the 7 is 700/760 of a bar, which is 0.92 bar or 13.3 psi.
True. But your wastegate and/or actuator could be stuffed/sticky and not opening properly, hence giving you big boost until the exhaust manifold pressure rises into stupidland and blows it open a bit more, leading to spike then drop.
No, fuel is your first concern. Overboosting while it is lean as shit will KILL your engine. You have to stop doing it until you have diagnosed the lean issue.
No. Put a gauge on it. Don't f**k about with crazy secondhand ways of trying to work out what the fuel pressure situation is. Do it properly, measure it directly.
Another regulator will not magically make a failing fuel pump work any better anyway!!
Fuel pressure gauge gets teed into the fuel line, and you run it out of the bonnet and hold it in your hand/lap/passenger's hand/lap as you drive. If the pressure starts high and plummets on load, you know what's happening.
Even better, do it on a dyno.
Upstream means up stream, meaning in the direction from which the flow is coming. The fuel pressure is set by the regulator at the outlet of the rail. You can only measure the rail pressure at a position upstream of the reg, which means at the inlet end.
Can a jammed actuator cause black smoke on boost somehow?
Not directly. I mean, there's nothing about what is happening at the wastegate itself that will generate smoke right there.
But....if the car is overboosting and the ECU is dumping in fuel (because that's what they do from factory) then, yes, black smoke will result.
It will also smoke if it is pinging its tits off too.
  • Like 1
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
