Hey guys I have a 2001 series 2 R34 GTR and  the 4WD and ABS lights are on and I have no idea how to approach it. Car was running great up until one day I had a flat tire because a wheel cracked. Then I have replaced all four tires and hope it will go away but unfortunately it didn’t. I have tried the following methods but have no luck ?
-checked the consult port but there’s no cable wired in for pin 4 (probably because it’s just a base model and not a V-Spec) (see attachment)
-I tried looking at the trunk for the blinking red light on the attessa ECU (below the hicas ecu) but do not see anything.
-I checked the fluid level and it’s all good.
-I can hear the attessa pump kicks in when I put the car in accessories mode so I know the pump is definitely not the problem
-tried wiggling the TPS sensor (as someone suggested on forums) and no luck ?
-Tires are 265/35/18 and all at 35PSI
Any input will be welcomed! Thank you!
Edited by ggr34
11 minutes ago, ggr34 said:
Hey guys I have a 2001 r34 series 2 and I have the 4WD and ABS lights on and I have no idea how to approach it. I have tried the following method and have no luck :(
- checking the consult port but there’s no cable wired in for pin 4 (probably because it’s just a base model and not a V-Spec) (see attached picture)
any input will be welcomed! Thank you!
See if this helps:
Or this
31 minutes ago, ggr34 said:
Hey man I appreciate your help but unfortunately none of them related to my problem :(
? It looked like your problem was that you were trying to short out the wrong pins.
Check ABS sensors that lines up to ABS rings on all axles - happened to me a while back after done what you've gone through mine is R33 GTR, had same problem and somehow I decided to crawl underneath rear end for some reason I can't remember at the time (still can't remember now) and I noticed one of sensor didn't line up to ABS rings on rear left CV, pushed the CV back in the diff and problem went away.
Also, have a look at tyres and see if they all are the same, if one is slightly off, it'll do that, also happened to me.
  • Thanks 1
I’m pretty that’s the right pin. In order to get the attessa to display the error code you will have to short out the forth pin at top roll and the first pin at the bottom roll. As you can see in the picture I have attached, theres no cable going into the forth pin at the top. Correct me if I’m wrong
I thought the two links I supplied corrected you. Both suggest its two adjacent pins either bottom left or top right depending on orientation. And its certainly not the case that you have to have a V spec to do this.
  • 5 years later...
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
