4 hours ago, GTSBoy said:
If you think about the violent thrashing of broken parts between the cam lobe and the valve while it's all flailing away at "over rev" speeds......
that makes sense, metal shards flying everywhere, scratching cam shafts lobes and stuff. Do slightly scratched camshaft lobes matter too much? or is it fine as long as  the cam lobe can spin freely without getting caught up?
1) Yes of course any damage to the cam lobe surface will cause damage/wear to all other parts it is in contact with.
2) Yes of course breaking a rocker arm can/will bend a valve stem
3) Yes of course a bent valve stem can cause a valve stem seal to leak, or crack a valve guide.
Didn't you get this car originally with a broken rocker arm?
Hey thanks for that, and yes to your question.
    • Jax Tyres this Monday morning. Front lifted 15mm Back lifted 12mm Quote1, $175 per tyre + wheel alignment. Quote2, $660 inc wheel alignment. paid $298 for the lot.
    • Finally have an update on this  Rack came in this week so I did a test fit. You do need the S chassis bushings since the rack is 5mm thinner than the R33 rack. The main issue I foresaw and ran into was one of the hardlines not lining up properly with there it's meant to on the rack. After some gentle coercing and bending very slightly, I managed to get it to fit without any kinks and keeping the hardline pretty much in all of the factory mounting positions. I did have to unbolt all of the soft mounts to move the line around so I could snake it out and bend it safely but it looks good to me for now. I'll update when the rack is fully bolted in and functioning.
    • I hear this thread needs an update following its adventures last Wednesday!
    • What are you thinking makes a sequential shit to drive on the street? About the ONLY thing I can think of, is if you're wanting to be able to roll up to lights in third or second and pop it straight into neutral, or you want to come down two or three gears, say out of 5th and back to second, but they shift quick enough it doesn't really matter
    • I'm not a drag racing guy, but that was a good watch. Didn't Ibrahim's car have some cooch! But the big question is....WTF is with so many of them running without seatbelts!
