Hey as above but was wondering if it's worthwhile staying oem or going aftermarket.
Specs:
Approx 200rwkw rb20det
Tein coilovers
Strut braces front and rear (nismo I think)
Street driven, no drift or drag (except street)
18 inch wheels and tyres
Needs L and R top ball joints
L front inner rack end
Is there maybe an aftermarket kit which has all the suspension bits so that I can change them all at once?
Finally is it a fairly easy diy job and if so what tools will I need?
Thanks in advance!
Ps I have attached my alignment report; pretty sure it doesn't look too bad?
I assume that you just need to change rack ends and upper ball joints. There are no "aftermarket" as in "modified" "upgraded" parts for those. There are "aftermarket" as in "3rd party" with some being equivalent to genuine Nissan/Pitwork and some being obvious cheap nasty China quality.
If you're asking about other suspension arms, like upper and lower control arms and caster rods, then there are many options. Only some of them make sense (financial, or technical). But that's not what you were asking about, was it?
Kudos, Amayama, JustJap, various others, all stock Nissan/Pitowrk parts. You can also get them from numerous vendors on eBay.
I don't even bother, for stuff like this. I just get my bro-in-law to buy them (he's a mechanic w/ shop) and he gets them from his usual suppliers. If you're not going to tackle the actual swapping of the parts (and these are reasonable sized tasks, so I'd guess you might not) then just getting the mechanic to source them for you will make him a little happier, as he will make some markup on the parts. Most mechanics are only so-so happy to fit owner supplied parts. They'll do it, but they won't like you for it!
    • HFM BM57 has a "bad" knee point, IIRC. It's not the same thing as the later R chassis MC.
    • The ATTESSA is functionally identical to R34; there were a bunch of JDM models that continued ATTESSA including Fuga/Q70, Skyline/Q50, Cima etc as an option. All with Auto only and I think mostly for snow regions. AFAIK there were no AWD VR30DDTT sold in Australia - it is on my to do list to check regs for racing a LHD car in Targa/ATR/AASA/CAMS events because if I can get the auto to work it would be interesting to run a 4wd car The Ecuteck TCM tuning is the same model as their ECU tuning, they already have it for R35 and Dose's favourite, BMW. You buy "points" to allow your computer to be tuned, buy either a bluetooth (phone app) or bluetooth+USB+Key (phone and PC) dongle, and pay for a tune that will be locked to your tuner ( ). You can also access the tuning software yourself but 1. it is mega expensive and 2. these computers have a billion parameters that intersect, so how could you ever spend enough time on it to get a decent result.
    • Or, is it a case of what it is like owning an R series Skyline? NFI what the previous owner has done or fiddled with... Ha ha ha After reading through this thread, I went on a bit of a research about the Q50/Q60. Now I'm quite intrigued by them! Is the AWD in them more like a WRX where it's always AWD, or is it more like the ATTESSA in the GTRs? By the sound of this TCU tuning, this sounds like a case of someone has made some real software for it, and you just need the right piece of hardware, and then you license that specific vehicle/TCU. Or is this a case of the software will be really expensive so only a few tuners have it, and you still have to pay a license per vehicle?
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
