As the title says, my s1 r33 rb25de is lacking power, everytime i hit the gas the car seems like its gonna stall, like lossing heaps of kick or miss fires and than takes off.
Can anyone please tell me wat speed there at at 3000rpm on every gear?
e.g:
* 1st Gear @ 3000rpm .............?
* 2nd Gear @ 3000rpm ............?
* 3rd Gear @ 3000rpm .............?
Now i know these kinda depends on wat mods you have, but yea long as i got a fair idea where i'm at. And there is nothing wrong with my speedo. :)
Thanks in advance :)
EDIT: ok guys lets just focus on the bottom end power.
https://www.sau.com.au/forums/topic/48089-please-helplacking-power/
maybe look at getting it carbon cleaned? my car lacks a bit of power to i think and i'm going to get it carbon cleaned coz i took my throtel body apart and it was full of shit
i know at 100km/h in 5th i sit on 3000rpm
i'll find out the rest for ya tonight
(i got a s1 r33 rb25de with just a zorst done)
regardless of what power you are making, you will still achieve the same speed in each gear at a specific rpm. power will just determine how long it takes to get there. correct me if i'm wrong.
I'm lacking power recently as well - the engine feels really choked up or something.... anyone else having similar problems?
e.g:
In my car the loss of power was the coil packs not having the punch from about 3000-5000rpm. This started when it was still N/A and caused most of my dramas tuning after the turbo was put on. I replaced 5 packs to get it back to normal, and today the last of my R34 packs died so it's starting to miss again and lose power in the 3000-5000 range :D
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
