They earth so they need mounting half descent being my problem and being 008 they pack alot of punch so nothing too close otherwise she gonna spark out I just figured because they make these 008 for the RB especially that there would be a R33 or R34 bracket that holds them on the rb25det
Hell no buddy they were listed on eBay to fit my vehicle a 97 rsfour stagea, got the part opened the box and obviously wrong part. Clearly won't fit without modifications to a bracket of some sort. After research they are much stronger than 005 but I'm just after advise on how to mount these, or even if they will work on my series of 1 stag, somebody could want swaps and have my reverse problem. No pissing contest but kudos won't refund or send me the correct part without taking 30% so sau it is
I would be more than surprised if any Splitfire was more powerful than any other Splitfire.
There is no real difference between a Splitfire made to suit a vanilla 25 and a Splitfire made to suit a Neo25, except the physical fitting.
Your research is faulty. Whoever is saying that one is stronger than the other is smoking crack.
(And it is not that hard to work out that if you have a Neo engine, you need Neo coils.)
And if Kudos are really wanting over $800 for a set these days, it is madness to even consider buying them when the step up to some R35 coils is not that far.
I bought a crate engine out of a series 2 laurel rb25det neo, I have sorted everything out all but the coil pack bracket. When I got the engagement me it had 008 just floating point under the cover. Upon putting it all together I can't find a bracket to install them properly other than a rb25det series one 005 coil pack holder. eBay or JDM pages don't list anything to hold these 008 in place.
Just draw one up with the required holes on paper. Then transfer to suitable piece of ally and cut the holes and shape the outside. Take you 2 hours, max.
That sounds like a crock of shit to me.. I've they've sent you the wrong item surely they'd offer an exchange... ? Unless you ordered the wrong part number?
  • Like 1
    • Initially I thought having a pair of Recaro seats would be a big bonus, it turns out these do get a little uncomfortable on long journeys (my fault, not the seat). I had a look through the GSM Performance website at reclining seats and booked an appointment to visit their show room. I got the Recaro Sportster CS for the R34 from here, was very happy with the service received so of course a re-visit was in order. Unfortunately the two Corbeau seats I had chosen aren't on display but they had 4 other options available. Two seats dug into my back, one dug into my legs and the other was perfect. I also found out that Recaro seats use a larger bolt pattern so some adaption was required. Luckily GSM offer some universal adaptors that should solve this problem. I searched the interwebs for price comparisons and Corbeau themselves were the cheapest at £300 cheaper (for the pair). I asked GSM if they could price match, unfortunately they couldn't. I later received an email saying Corbeau would honour them the same discount, but the purchase was already made. I did however order the brackets from GSM, both arrived on the same day. I started with the passenger side seat, knowing this was going to be a little trial and error. There are 3 mounting holes at the front and 2 at the rear on these JURAN Racing seat rails.  With the adaptor brackets mounted, the allen cap bolts started to push into the seat, NOT GOOD!  The rear mounting holes lined up but there were issues at the front. The holes were 1/2 hole out, so the brackets got a tickle with the drill to modify the holes. The supplied bolts weren't going to be long enough and a spacer was needed to stop the adaptor bars from bending. A local fasteners company supplied be with some nylon spacers and longer bolts (M8x30, although these will be replaced with 35mm long shortly) A before and after I pre-drilled the front bracket before making a start on the driver's seat to save some time. And in no time at all that was in the car too. The all black seats have transformed the interior and these are MUCH more comfortable. The only downside with the new Corbeau seats is I sit a little higher, but I'll happily accept that over discomfort. The Youtube video can be found here: https://www.youtube.com/watch?v=wPyttKPktXA
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
