2 minutes ago, BK said:
Yeah I know Nitto "rate" the 3.2 to 10000rpm and they "rate" the 2.8 to 11000rpm. As my 2.8 crank came from them with test results balanced up to a confirmed 10000rpm, I bet the 3.2 is only "tested" before delivery to 9000rpm to be safe, knowing realistically no one is spinning a 3.2 past 9k and a 2.8 past 10k.
Did you pay extra for it? I have a 3.2 but i didnt receive such a report.
Yeah ? I have purchased 2 Nitto 2.8 stroker kits before and both were included with them from Nitto. 1st crank went to Rick Corbett engineering in Adelaide and 2nd crank went to CRD and whoever they use for machine work to double check Nitto reports. I'll dig up one from Nitto.
There's a big difference between spinning a crank up to high rpm bare (without actual engine loads, ie combustion) and using it at the same rpm making a lot of power. There's a certain sized grain of salt required when looking at a balancing report that says the crank was spun to X rpm. Sure, it was fine under those conditions, but add the reciprocating loads up and down the conrods onto the journals and it is suddenly not the same as spinning it from one end.
  • Like 1
Absolutely, but what else can you go off ? The fact the pretesting is not done right up to claimed max rpm is more realistic real world documentation. I wonder how Nitto is coming to the conclusion of their max rpm and power limits then ? Probably just estimates / calculated guess ? Anyway its proven to be pretty good gear, and more than adequate for what 99% of people are going to throw at it.
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
    • D2 and Ksport are essentially the same thing and basically just generic Taiwanese manufacture. Better than ChinaBay crap, but... not top shelf. Öhlins have got to be some of the best dampers around, so likely to be a good option. It's going to get to the point though where I suggest you buy from Oz. We have at least 2x excellent options here. If I were you though, I'd be talking to KW about doing something for the R33. There's bugger all difference between that and the 32. In GTR land, anyway.
    • KW only offers a set for the R32 GTR. Popular options are D2 racing, Ksport or Öhlins. I have a D2 Racing coilover set, though I don't know for sure which one.
    • Well, the good news is you have more than one very good option for new coilovers in and around your country. Worth the drive over to KW to talk about GTR stuff.
