Hello.
Recently picked up an R33 GTST, S1.5, and I am very worried about the timing issues.
The car ran rich when I got it, which was fixed by adjusting the TPS to correct voltage, but the idle seemed a little off still. I took it and got it retuned, as the last tune was very old and outdated.
The car made 425 RWHP on a hub dyno, at 15 PSI. Tuned on Apexi Power FC and a GT3582. The car has very little knock on the hand controller, and seems to run fine. The tuner said however he had to advance the timing a massive amount, and believes the ECU is misreading timing, and it is an ECU fault.
The timing degrees is at mid to high 20's under full boost, which seems very high. Again, low knock (under 30) on Power FC sensor. It was running similar timing to this for the last 7-8 year apparently, and had a very similar ignition map on the old tune.
What's the go with this? How can I get the timing to a 'normal' level? Has the belt slipped? CAS failed? I am concerned the Power FC knock reading is inaccurate and I don't want this car to explode, as Covid tax meant this was not a cheap buy!
Cheers all!
https://www.sau.com.au/forums/topic/481616-rb25det-timing-advance-issues/
2 minutes ago, Murray_Calavera said:
Did anyone even check the timing with a timing light?
Are you on E85?
Apparently the tuner did check it with a timing light- going to go get it rechecked and the CAS adjusted if it's out. Second opinion is probably cheaper than an engine rebuild
i'm on pump 98 also
Edited by CLEM0
I'm a bit confused, so the tuner checked the base timing, found that what the timing was reading and what the timing was in the ECU didn't match - and then tuned the car anyway?
Do you know if the tuner used any type of knock ears during the tune?
Apparently the timing matched according to the tuner, and only reads wrong when not on idle, which sounds odd. Apparently this is why the ECU might be faulty
Don't think any knock ears were used either
Idle strategy involves timing correction, you need to disable the idle closed loop by unplugging the TPS before checking the base timing to see if it's synced to the GameboyFC.
I've been reading about all of this, setting the CAS and all. Would the CAS being out cause all the timing numbers displayed by the 'GameboyFC' (haha) be out of sync? Or is the timing is shows what the actual engine is seeing?
Listen, this shit is very simple.
Step 1: #1 sparkplug out.
Step 2: Engine to TDC firing on #1. You will have to convince yourself that both cam lobes are facing away from the cam followers on #1. Use a screwdriver down the sparkplug hole to find TDC. This is done by marking the screwdriver against some feature (the edge of the hole for example) while the piston is rising and close to TDC, then rotate past TDC until the mark is back in the same place. Note the engine position at the pulley timing marks for both. TDC is halfway in between. If TDC is not right bang smash on the TDC mark on the pulley - there's your first warning sign.
Step 3: Now that you know that the engine is mechanically telling the truth about TDC, the next paranoid step is to make sure that the cam timing is not 1 or more teeth out on eaach/either cam. Timing cover comes off the engine. You will have to rotate the engine several times until the timing marks all line up at the same time. If you cannot every get them to line up, there's a significant warning sign. You simply can't get the ignition timing to make sense if the cam timing is not.
Step 4: Throw the PFC in the bin.
Sorry, got ahead of myself there.
Um, Step 4: After all this, it is just a case of the usual stuff. Using a timing light (properly) to check idle timing against what the PFC says the engine angle is. "Properly" means disconnecting the TPS and triggering the timing light correctly. If the PFC says 15° but the engine says 5° on the pulley, then you have probably missed something in the earlier steps.
Step 5: Throw the PF ....ah nearly did it again.
Step 5: Find a better tuner. A good tuner is not necessarily a good mechanic. There is no such thing as a "good tuner" if they are not also a good mechanic when you are trying to solve this sort of problem. Also, trying to fix this sort of shit while the car is strapped to the dyno is a dumbness, because it costs a lot more to fix strapped on a dyno than it costs to fix it on the other side of the workshop.
  • Thanks 1
  • Haha 1
Thanks mate. I'd love to bin the PFC but I just bought the car and don't have the budget yet, but will eventually be getting a Link when I am experienced enough to go forged bottom end. Will need to buy a timing light during the week it seems
So if anyone is still able to help, I really thought I figured it out but I'm stumped again.
- Thanks for all the helpful responses, I took them on board and checked it all today.
- I have checked all timing on the car. Intake and exhaust camshaft markings line up. When these line up, so does the harmonic balancer, with the marking point (more of a shaved section than a point) on the timing cover corresponds very closely to the 4th marking, AKA 15* degrees on the balancer. (0,5,10,15...) Hard to say it's 100% perfect but it's very damn close as far as I can tell.
- The engine is also at TDC at this point. Marked a thin metal rod with a permanent marker, and got it as close as possible to TDC by visually watching for the point the marking was neither going down when the crank was rotated clockwise or counter-clockwise. It all lines up.
- Literally all the timing points assessed line up (not perfectly as it's all judged by eye so leave some room for error) but it's all close enough to not be an issue.
- The timing of the ECU and the CAS is within 2*. This was tested at idle, and verified under of around 2000RPM. Used a timing light with the signal directly attached to plug #1 with a lead, not the crappy wiring harness/coil-plug loom. As far as timing goes - it's fine. (Only thing I didn't check is crankshaft marking under timing cover as this is a big job, ran out of time)
- THE ONLY ISSUE I CAN THINK OF NOW- I have a receipt from previous owner for a very recent plug change, done within the last few thousand kilometres. They are 6 x new NGK BKR6E - great, or so I thought. Pulled them today, turns out they're gapped at 0.20 to 0.25mm!!! I have no idea who would use such a stupidly low gap. Anyway; would this have any effect on the ignition timing? I know it'll affect car performance overall, but will it mean that to make power I need seriously advanced timing, as the spark is not strong enough until the mixture in the cylinder is pushed right to the top, right up to the spark plug? (advanced timing)
- It's the only major issue I can find on the whole car. I verified timing several times as I simply didn't believe it all lined up. I was sure this was this problem. From the tests I have conducted today, I can pretty happily eliminate timing from the equation, for now at least...
-If I still can't find solution this will be my last resort before either a new engine goes in or I give up for now.
Thanks again for all the help in this thread all, hopefully someone can guide me from here!
8 minutes ago, Murray_Calavera said:
Let's take a step back and a deep breath, keep it simple.
What exactly is wrong with the car? Does it start, idle and drive well?
Damn... every other forum I used to get clowned for not giving enough detail, now too much- can't get shit right 😂😢
Anyway- Idle sounds choppy, did so both before and after retune, car struggles/won't start cold unless given throttle, misfires/shoots flames under light load (2-3.5k RPM). Does this randomly, which is now made worse since retune.
Drives fine, feels like about 400whp, goes hard. Only shows issues when approaching rev limit, about 500-800 RPM before redline it'll backfire hard occasionally, so I decided to stay well away from higher RPM until I can fix this.
The car actually runs and drives fine when warm besides isssues mentioned persisting. Cruises well, doesn't stall.
Idle still not amazing when warm but very hardly noticable choppy sound, retune set idle to 950RPM instead of 650 which improved it decently. Was really only bad when cold.
The main reason i'm going through all of this literally the timing numbers. The car makes shit all power under regular safe timing maps, so now they're far too high and that is what i'm struggling to figure out- why? The tuner only set them so high as he simply believed the ECU was faulty, as it runs very solid at stupidly high advance, and makes normal power for the boost and setup.
Just now, Murray_Calavera said:
These issues, have they been there the entire time you've owned the car? You've had it about 8 years now?
Sorry if I wasn't clear- had the car just over a week. Previous owner had for 7-8 years give or take.
I would never let a car run like this for more than 8 days, let alone 8 years
Ok, that makes sense.
You've got a dinosaur ecu, you could also have dinosaur injectors. Do you know what injectors you have?
Shitty side feed injectors could be the culprit for a lot of those issues.
When you say it makes shit power on regular timing, how much timing and how much power exactly?
Do you have a wideband? What are your fuel mixtures like in the areas you are having issues?
It's 2am. Just realised I measured this in inches. 0.020 inches in 0.5mm, and 0.025 is roughly 0.6mm.
Plug gap is fine. No idea what to do.
Nothing makes sense with this issue and not even mechanics who build RB engines for their job can figure out what is going on. It literally just doesn't make sense whatsoever.
Injectors are I believe 740cc side feeds. Will need to pull to check. Stock fuel rail, FPR 800 with no gauge for pressure.
I have a wideband from my old car but haven't got the bung I ordered from eBay yet to put it in. Car ran 11.5:1 on full boost according to tuner. No clue how he measured this....
    • I did end up getting it sorted, as GTSBoy said, there was a corroded connection and wire that needed to be replaced. I ended up taking out the light assembly, giving everything a good clean and re-soldered the old joints, and it came out good.
    • Wow, thanks for your help guys 🙏. I really appreciate it. Thanks @Rezz, if i fail finding any new or used, full or partial set of original Stage carpets i will come back to you for sure 😉 Explenation is right there, i just missed it 🤦‍♂️. Thanks for pointing out. @soviet_merlin in the meantime, I received a reply from nengun, and i quote: "Thanks for your message and interest in Nengun. KG4900 is for the full set of floor mats, while KG4911 is only the Driver's Floor Mat. FR, RH means Front Right Hand Side. All the Full Set options are now discontinued. However, the Driver's Floor Mat options are still available according to the latest information available to us. We do not know what the differences would be, but if you only want the one mat, we can certainly see what we can find out for you". Interesting. It seems they still have some "new old stock" that Duncan mentioned 🤔. I wonder if they can provide any photos......And i also just realized that amayama have G4900 sets. I'm tempted too.
    • Any update on this one? did you manage to get it fixed?    i'm having the same issue with my r34 and i believe its to do with the smart entry (keyless) control module but cant be sure without forking out to get a replacement
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if something was binding the shaft from rotating properly. I got absolutely no voltage reading out of the sensor no matter how fast I turned the shaft. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if shttps://imgur.com/6TQCG3xomething was binding the shaft from rotating properly. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
