  • 7 months later...
Late post but im putting together another rb for the drag season and have came across these pulsar turbos you guys maybe interested in, I have buddies that are beating the piss out of them on there jz's, they seem to hold up just fine and are 1/3 of a price of precisions. im currently on a 6466 but looking to make 900whp. im going to try the pulsar 7170 not even a 1000 quid!! good bang for buck
On 05/01/2023 at 1:54 AM, GTSBoy said:
I think the consensus is that the Pulsar turbos are good examples of cheap Chinese turbos, but that they are still cheap Chinese turbos, in that the tolerances/clearances etc are not....great.
Are there any good examples of this in terms of media we can see?
I've seen a couple of "just happen to be Garrett dealers/sponsored by Garrett dealer" people make these claims but so far have been involved in a pretty solid amount of Pulsar turbo based builds without seeing this issue.  The only issues I have seen have been regarding needing to make sure things are done up properly, ie - not assuming vbands are done up, or turbo speed sensor plug screwed in properly etc.   Have heard of 3rd party folks who are doing mix-and-match sells of Pulsars selling them with the wrong housing, ie GT35 turbine housing with GT30 turbine but that's not a build quality thing and could just as easily happen with the same people selling legit Garrett bits.
Edited by Lithium
And, to be fair, that could be the sole source of any noise I have heard.
So far I've not seen any reports from people I'd call "neutral" buuuuut I'm obviously open to finding out if they are something I should be more apprehensive about sticking up for.  I have nothing to gain personally, not a dealer or anything - like yourself just like trying to give people "what I know" to try and help them be best equipped to make the right calls... the whole "are you ok with buying a copycat" is a different ethical decision best made by the buyer.
    • Actually, that's not entirely true. It's also the same motor in the 1st gen Nissan Cube but they're rare as hen's teeth.
    • Yeah it is always worth testing and balancing actuators out of the box, just set the pressure regulator on a compressor very low (eg 5 psi) and increase it slowly to see when they both move.....unfortunately while you may be able to adjust the length of the actuator rod to minimise any difference, the actual pressure they move from is not adjustable so you need a well matched pair. And yes, the VCAM is probably contributing; the earlier in the rev range they come on boost and the slower the revs build (I think your demo was in 5th), the more you notice it.  Driving at WOT through 1st, 2nd, 3rd etc you will probably never hear it as any shuffling starts and is over super quickly
    • oh they were with that motor, you need to remove the engine to change the spark plugs (don't have to, but it does make it easier)
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
