Hi I’m just wanting some advice on some mods for my silhouette? Iv taken already taken off the stock air box an put in a pod filter and what not.. I’m just wondering what’s a good exhaust to throw on to get that nice RB sound as well I do plan on chucking on a turbo Iv heard that you need a 3inch exhaust when you throw on the turbo an hear when it’s n/a you can get 2 1/2 inch exhaust so any advice would help and be appreciated even any ideas on any other mods as well here’s a couple photos of my 31
let me know what use think of the air intake an what not aswel cheers
https://www.sau.com.au/forums/topic/481851-advice-on-mods-please/
Might be a stupid question but If I end up getting the 3inch exhaust can I run it on my car n/a will it change anything on my car in a bad way? Cause I just want to do a few things to make it sound better and go better as well get a few things done before I throw a turbo in it.. If I can put on the 3inch exhaust what one would use reccomend so the car doesn’t sound like shit any advice would be appreciated thanks
Been there done that. First thing you should do is cover/seal that pod filter, or install standard airbox. Sucking in hot air does nothing positive for your engine.
Sell your 3" exhaust and buy a GTS1/2 style exhaust manifold (6 to 2 to 1). . Buy two fat mufflers with 2.25" ends, then take it to your nearest decent exhaust shop and ask them to make you an exhaust with mandrel bends. Sound done.
Get a 'hotter' camshaft and Nistune. Install and tune. Upgrade suspension and brakes. Replace all flogged out bushes (e.g. rear trailing arms). Also invest in a working LSD. Learn how to drive, go to track days etc.
Once you're confident, sell the car or go all out on a turbo build.
There's a whole forum dedicated to your car ;)
https://forum.r31skylineclub.com/index.php
http://wiki.r31skylineclub.com/
  • Like 1
I haven’t got the 3inch exhaust yet i was asking for your opinions before I even bought it..
I’m already changing the front bushes I’ll get the mechanic to have a look at the control arms as well
are the gts1/2 style manifold 6 to 2 to 1 easy to find any links you can reccomend cheers
@niZmO_Man
@GTSBoy
another question I'm looking to eventually get coil overs for my car just wondering if use know any good ones where I don't have to spend an arm and a leg... I seen on eBay 1500 for only 2 lol.. I'm willing to pay 1500 for a whole set of 4 but yeah so any advice or links would be appreciated by the way I haven't done the s13 suspension conversion so I'D need r31 coil overs
12 minutes ago, niZmO_Man said:
Angry Industries had a sleeve for the front, you need to cut/weld your struts. The rear I think there are available replacement struts (S13 with top hat adaptors?).
Yeah I asked angry Industries no go, am i just better getting king springs all around? Bit cheaper less f***ing around and what not cheers
  • 1 month later...
https://otakugarage.com.au/product/nissan-skyline-r31-85-87-dgr-high-performance-coilovers/
pretty sure these bolt straight onto the r31 don't they? They suit the stock 2 stud bolts on the front end so no need to drill another hole for s13 front end, planning to install these on my r31 once the money comes in :)
If already got the extractors an exhaust done next will be getting alarm system and coil overs and saving up for vlturbo manifold.. was gonna do the cams but might do that last struggling finding any good cams especiallu lifters any links to help with that would be appreciated cheers
What do you use the car for?
For the amount of money you would spend getting 20hp out of the 30 with NA mods, you could have a good chunk of cash towards a little boost netting alot more, lots of kits available
You would need a few drivetrain solutions though
Hammer time
  • Like 1
I won't bother with the cams then
If anything I'll just finish the handling first before I even throw in a turbo
Just wondering anyone has much advice on the sway bars been told to get 27mm front sway bar and then dual sway bars... problem is I want to drive the car as a daily but at the same time if I want to have a little fun I'll do it but if heard dual rear sway bar will make the rear to lively for a daily car any advice? As well I'm not sure why I'm being told to get wider sway bar on the Front?
    • Hi guys my TPS voltage is reading over 2v at idle.  My Haltech ECU is reading around 40% throttle position at idle also which is really strange. Note the actual throttle position sensor is brand new…    anyone have any experience with this or know how to calibrate it on Haltech ?
    • The OEM disk will not work on any AEM ECU, you need to use the one they made. You shouldn't have to flip the CAS or whatever you were describing, if you set the ignition sync offset correctly it can't backfire. Make sure you're using a spark plug lead on coil 1 instead of the timing loop to avoid weird issues with the timing light. Double check that your timing settings are actually correct, like is the 24 tooth configured correct or should it actually be 12 teeth for 1 crank revolution? I also found this: 305817248-AEM-Undocumented-Settings-v1-2.pdf
    • Yeah, I don't believe the M35 uses a deadhead system.
    • Have you done your thinking backwards? 3 bar, 43.5 psi pressure drop being the presumed specification for an injector, means you need 3 bar upstream when they are firing into atmospheric pressure, and more upstream pressure than that when on boost (you add your boost to your rail pressure to maintain 3 bar across the injector) and you need..... less pressure upstream when you have vacuum in the manifold. So, presuming that you're idling at -10 psi, then you only need ~23 psi in the rail. I realise that I did not need to say all of that to you specifically Matt, once you'd realised your mistake. It's mostly there for complete clarity for others.
    • Have you reached out to the guys at Spool Imports? They are a Ross dealer, I can imagine they would have the rings just sitting on the shelf (I could be wrong).
