I've been searching all the fourms and haven't been able to find a solution. Hoping to get some help. Anyways neo swapped my gts25 back in 2018 and recently have been trying to work out some of the less important issues such as the a/c I found my outside air temp sensor a few days ago and was hopeful that would fix the solution I had a shop do a ac conversion from the r12 to the 134a a few months back. Anyways the diagnostic on the ac unit shows the water temp fault but all the temps show fine that the sensors are reading correctly but ac doesn't get cold just warm. The compressor itself doesn't kick on. About the build I'm running stock r34 gtt ecu,  custom built harness from wiring specialties, stock r32 ac compressor never broke the lines during the swap. Any help on this would be greatly appreciated it's spring time in Texas so trying to get this fixed before the 100+ temps this summer.
https://www.sau.com.au/forums/topic/482179-neo-swapped-r32-ac-issues/
You also need to do something fancy about the refrigerant pressure switch. The R32 one is 2 wire, I think the R34 one is 3 wire, and I think the R34 ECU doesn't want to work with the R32 switch. Needs some extra wire and a diode, or something else not too hard, but annoying to work out.
Was done on mine, but I can't remember exactly what. Was 10 years ago.
Yeah I checked all the sensors and they're good I'm thinking it has to be the switch I can trip the relay to kick it on but the control unit itself doesn't kick it. Anyone happen to know where I can get one of the r34 switches I looked a little today but couldn't find anything.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
    • More so GReddy oil relocation kits, sandwich plates, etc. all use 10AN fittings. And same, I've only used 10AN and my car sees track work (circuit, doing laps, not 10 sec squirt business).
