So I’m upgrading intercooler and fuel hanger/pump, have 1000id injectors e85-9 Garrett’s making 320awkw currently.Will upgrades to cam gears and type B poncams assist much in power gains on my Gtr32.
Im going to tidy the engine bay by powder coating the cam covers and figuring out weather to upgrade at this time. Advice would be great.
Edited by Matty George
https://www.sau.com.au/forums/topic/482238-cam-gears-and-poncams-next/
Hi again Matty. Just do the cam gears and keep the stock cams with your -9 turbos. If you cam it you will absolutely make more power, but your car will be slower everywhere except the drag strip.
Your call
  • Like 2
  • Thanks 1
Don't get Tomei cams if you're wanting new cams, get some decent Kelford cams, an intake cam gear (advance its mum) and install new valve springs (avoid Tomei junk), retainers and valve stem seals.
Yeah but with -9s car will still be slower for a streeter, even with the most baby drop in L182-A Kelford cams.
You're right though with the Tomei valve springs, how shit are they ? Caused me nothing but problems. The Tomei type B is, how did you put it, "made from a child's faeces"  😂 That still cracks me up.
That's correct, longer duration will move the torque/power to the RHS, however will also introduce more torque/power. This is where the intake cam gear comes into play, advancing that intake as much as possible (within reason) will pull that power curve back and the net result is nearly similar low RPM driveability but now with a wide power band :)
A bit of a balancing act.
Tomei cams & Tomei valve springs should not exist lol
  • Like 1
Yeah I've played with this on my -9 33 with this with Tomei cams. Ended up going back to stock cams with I think about inlet advance 4 and exhaust cam retarded 2 degrees.
I think -9s would actually respond to a 10mm+ high lift cam with less than 260 duration, but most people are not going to do such big head modifications with such small turbos, or twins at all.
You are completely right though, but cams just not worth it to increase 10 - 15w at most top end.
when you do end up picking a set of cam gears i would go with the kelford ones. i think there the only cam gears with the 5 mini helicoils and seem very high quality compared to tomei hks etc. cheers
  • Thanks 1
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
