So I’m upgrading intercooler and fuel hanger/pump, have 1000id injectors e85-9 Garrett’s making 320awkw currently.Will upgrades to cam gears and type B poncams assist much in power gains on my Gtr32.
Im going to tidy the engine bay by powder coating the cam covers and figuring out weather to upgrade at this time. Advice would be great.
Edited by Matty George
https://www.sau.com.au/forums/topic/482238-cam-gears-and-poncams-next/
Hi again Matty. Just do the cam gears and keep the stock cams with your -9 turbos. If you cam it you will absolutely make more power, but your car will be slower everywhere except the drag strip.
Your call
  • Like 2
  • Thanks 1
Don't get Tomei cams if you're wanting new cams, get some decent Kelford cams, an intake cam gear (advance its mum) and install new valve springs (avoid Tomei junk), retainers and valve stem seals.
Yeah but with -9s car will still be slower for a streeter, even with the most baby drop in L182-A Kelford cams.
You're right though with the Tomei valve springs, how shit are they ? Caused me nothing but problems. The Tomei type B is, how did you put it, "made from a child's faeces"  😂 That still cracks me up.
That's correct, longer duration will move the torque/power to the RHS, however will also introduce more torque/power. This is where the intake cam gear comes into play, advancing that intake as much as possible (within reason) will pull that power curve back and the net result is nearly similar low RPM driveability but now with a wide power band :)
A bit of a balancing act.
Tomei cams & Tomei valve springs should not exist lol
  • Like 1
Yeah I've played with this on my -9 33 with this with Tomei cams. Ended up going back to stock cams with I think about inlet advance 4 and exhaust cam retarded 2 degrees.
I think -9s would actually respond to a 10mm+ high lift cam with less than 260 duration, but most people are not going to do such big head modifications with such small turbos, or twins at all.
You are completely right though, but cams just not worth it to increase 10 - 15w at most top end.
when you do end up picking a set of cam gears i would go with the kelford ones. i think there the only cam gears with the 5 mini helicoils and seem very high quality compared to tomei hks etc. cheers
  • Thanks 1
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
