17 minutes ago, r32-25t said:
9k Plus hoses and fittings
That's a given isn't it ? What they do imply though (not sure if I'm correct) is that the 4wd dry sump pan is supplied. Is that the entire modified sump supplied ?
The Ross kit is the same price but clearly need to send your existing sump to get modified additionally, which is around $1000 - $1500 from Lewis engines.
I estimated about $12k installed for the Ross kit doing it yourself.
22 hours ago, BK said:
I notice the Hi Octane dry sump kit gives you a front or rear reservoir tank option. I'm assuming front means engine bay anyway. Not bad at around $9000 all up.
There is an option also to keep the air con.
If so where are they putting the external pump ?
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
