I believe there is a second brass air flow restrictor pill somewhere, I think it damps the feed of manifold pressure to the stock boost control system. Does anyone know where it is, and if its the same diameter as the famous one that is often removed to get 0.9 bar?
I remember a post saying one is under the intake manifold, I guess in a tube feeding manifold pressure, but someone else posted it is built into the metal pipework..
If one is reverting from an ebc and both pills have long gone, would like to know where it is supposed to be fitted, and if they are interchangeable.
There is a second restrictor, and it limits boost to roughly 22psi.  However you won't find it in any normal engine as it's only added to Nismo S/R engines.  I guess that's how Nismo decided to increase boost without active boost control device.  I don't know much about it, I just happened to see one in a Nismo S1 engine under the intake plenum.
Edit: This S1 engine was in a R32, so it's not limited to just R34.
Edited by TXSquirrel
  • Like 1
thank you! in S15s according to a digram on nistune the two pills supposedly bracket the boost that the solenoid works with, via a ratio of one to ‘tother dia. Would this second one logically be larger or smaller than the normal one? I guess its function is to raise the boost floor the stock system works within.
on an s1/r1 would the normal one (the one commonly removed on stock r34s), have a larger hole than standard?
(am helping a friend get his r1 boost control system back to stock. in the dark with these two restrictors, a bit)
Edited by syd_gtr
When I said I don't know much about the this, I should have said I don't know anything at all instead.
That R32 was just a customer's car at a shop I visited, I thought it was bizarre so I took a picture.  They did confirm first pill was still there before they took the engine apart, but I didn't ask any other detail about it.  I guess you will just have to figure out the diameter through trial and error.
Edit: I doubt you need both pills to control boost at a higher psi.  Nismo may have left that first pill in place for originality and could be redundant.
Interesting. A restrictor would function for pressure reduction if there is airflow, but also a damper of some kind to moderate the function of the solenoid, which has a duty cycle. Guess I'm going to have to try to find out from someone in Japan what's up with all this and/or some trial and error as you say.
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
