Hi all. Think I am having issues with the ignition system on my R34 GT-T. It has Splitfire coils but I am pretty sure I am having ignition breakdown on one of them once the boost goes past 14-15psi. I had the exact same problem in my old R33 and that was later tracked down to the factory ignition coils. Car drives really good and even on partial throttle it will pull quite well but as soon as the boost starts to climb, the engine note changes and the power drops off massively with almost jerking hesitation. It will still rev out (I only went up to 5K) but you can tell it just hated it.
I inspected the ignition coils and two of them look to be much newer looking than the other four. Just cleaner looking and the blue colour is much brighter. I am pretty sure someone has been in here before and maybe changed a couple of failed coils. Spark plugs all looked pretty much the same. Couldn't see any difference there.
For the guys with tuning experience, would I be ok getting the R35 ignition coil kit and just fitting it in there. I don't want to mess about with the Splitfire ones any more. Could I drive it like that without adjusting dwell settings? If that isn't a good idea could I at least drive it to a tuner with R35 coils fitted? I have bigger plans for the car down the line but currently it is tuned for just under 300kw on e85 with GT3071R pushing 20psi. I want 400kw down the track so an engine rebuild and turbo upgrade will be in the pipeline. I just want the car to run to its full potential for the moment.
Sorry for the long post guys but just wanted to give as much info as possible so that you can give me the right advice. Thanks for any help.
https://www.sau.com.au/forums/topic/482607-ignition-coil-upgrade/
Yes, not a problem. The dwell time for standard RB coilpacks is lower (shorter charge time) than what the R35 coilpack saturation point is. This just means if you leave it at stock dwell you're not getting the full energy potential from the R35 coilpack. Even so, the R35 coils at stock RB dwell times still massively outperform the stock or Splitfire RB coilpacks anyway.
Just get them and whack 'em in, money well spent 👍
  • Like 1
You're an absolute legend. Thanks bud. Dusting off the old credit card right now.
On 09/07/2021 at 7:36 AM, joshuaho96 said:
You might be able to find those coils for cheaper by searching for Hitachi IGC0079, in the US RockAuto sells those coilpacks for 55 USD/73 AUD each. Not sure how to make sure you're getting a genuine coil though, there are counterfeits everywhere for these parts.
Its not hard, you buy from reputable resellers in Australia like Golebys, Just Jap or Kudos Motorsport. You could even order the coils direct from Nissan if really really worried and purchase the mounting / wiring separately.
The coils aren't the expensive part, it's only about half the price of the kits as the billet brackets and wiring harness make up the other half.
What about Godzilla Motorsports kit? They seem to be a fair bit cheaper than others. They also sell genuine R35 coils or they have an option of their own "high output" coils which they reckon output more energy than the OEM R35 coils. Even if that is the case the long term reliability would be worrying me. They want $900 for the genuine kit but which is fair whack cheaper than PRP kit from Golbey's. Which would you go with? It's only a money saving if it's just as good. If not then I much rather buy the PRP kit and be done with it.
Yep the were the first ones I seen selling them. I have the Godzilla motorsport kit on my blue 32 with the genuine unmodified Nissan coilpacks as I wanted the genuine coils. Full kit was about $1200 from memory for coilpacks, billet bracket and wiring harness.
Damn.......they have the genuine kit on special at the moment for $900. I should jump on that. My understanding is that the R34 Neo engine the R35 coils are direct plug in. No loom needed. Is that right?
Thanks man. You've been a huge help.
  • 2 years later...
I understand that the R34 ECU can be sensitive to what is going on wrt the coilpacks/loom. You'd be well advised to put a Consult reader onto the diagnostic port and read the codes. The one(s) in the ECU will be the ones most likely to tell you what's going on. The TCS light will be a secondary effect.
  • Like 1
On 4/18/2024 at 11:47 PM, shortyboy said:
I just did the R35 coil pack conversion with Hitachi coils. Now I'm getting TCS, slip and cel lights on. Car runs great and better than before on factory coil packs. Has anyone else ran into this issue?
Pull the codes. I have seen a code 21 for primary ignition circuit fault on these conversions for some reason, I'm not sure exactly how the ECU decides this either.
  • 1 year later...
On 02/05/2024 at 10:23 PM, shortyboy said:
Will do thank you
Over an year later, I'd like to ask what as your solution in this. Did you keep the R35 coils with the stock ECU? Or slapped the Link in and tossed the 90s chip in the bin?
I installed my link ecu shortly after. But car ran fine with stock ecu and r35 coils, just had the traction control and slip lights on.
  • Thanks 1
    • BRUH, one of the biggest mistakes of my life..... and i've had plenty ;[)
    • @Murray_Calavera iam just considering options 🙂 of course it is very expensive so that why i ask here 🙂  @joshuaho96 I looked at that GCG hybrid(i remember looking at it few weeks before) So this is "that" hybrid where i send them my turbo and they upgrade the inside to Garrett stuff and then they send it back. It cost around 1200-1300 USD which is FAR cheaper than the HKS and it is what iam looking for(i just do not have experience like this...to send something off to "upgrade" ) @tylink720 that is like 150 USD turbo no? 😄 I dont think i have the "ease on my mind" with this kind of turbo. I just put over 7000k USD to "LINK" up my engine...dont want to blow it up with cheap turbo 😄     EDIT: https://www.cj-motor.com/gcg-turbo-charger-for-nissan-rb20det-rb25det-high?srsltid=AfmBOooVeOZ6CZ6r1AIv5m-KPaa6BvudIPJTY8LW78khkd-gQlsaCht9 I looked at this and it seems ok? It is that CGC hybrid and it costs around 1250 USD (with back shipping). Do any of you have experience with this hybrid on NEO turbo? I quickly look thru the forum/web and it seems very good.
    • Echo the awesome sentiment 👍 Definitely a car worth saving. Looking forward to seeing updates as well.
    • Scenic roads, stunning skylines, and Chickos to finish it off! Join SAU NSW as we cruise through the Royal National Park and along Lawrence Hargrave Drive to Figtree! Sunday 26th October 2025 4:30PM Meeting Waterfall Station Parking 5:00PM Cruise Departure Royal National Park > Lawrence Hargrave Dr > Memorial Dr > Sid Parrish Park 6:15PM Arrival at Sid Parrish Park Figtree Meet Location: Waterfall Station Parking Final Destination: Sid Parrish Park RSVP: https://forms.gle/E4s5SiRKQfDdypky8 *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • It's funny, as Ive seen plenty of people use them in cheap builds on YT. And they actually go okay, even though a lot of other maxspeedingrods stuff is terrible. Those turbos seem reliable enough, the only part being, a good quality turbo that is "identical" to it, will out perform it day in and day out. In both a lower boost threshold, and the ability to flow more air at the same boost pressure. As a cheap cheap replacement, not a terrible choice. For cheap and shouldn't blow in a day, not terrible (like other eBay/Temu turbos) for low cost and still decent performance, that's where the question comes in to play from the results I've seen. I'd actually find it hilarious to buy one, and strap it to a paddock basher or some other cheap as POS originally NA car, and send it to the moon!
