Hello,
During highway around 3000rpm I'm at around 840 in sixth gear.
During a WOT second gear to 4th gear I'm at 960 and I stopped at this point... (MFD starts to warn me)
Engine iddling I'm at about 550
I didn't pay attention in the past to this as I was solving others issues...
The car is fully stock, everything seems to work good
It looks like the engine is running too much lean ? Should I make some log data for the AFR ?
I suspected the fuel regulator and the fuel pump to be 22 years old....Is it probably the issue ?
THanks for your inputs
https://www.sau.com.au/forums/topic/482685-stock-r34-gtr-high-egt/
I had this issue and it turned out to be massively wrong timing making the exhaust valves open too soon. The tuner had seen too many rb26s of all kinds and I think they forget what stock is supposed to be like. They just said to me dont worry about it, metal doesnt melt at that temp.
timing probably isnt your problem just saying that you know best that it has changed, so get to the root cause.
So I try to set the ignition to 15,20 or 25 doesn't make any difference..
I have 2.6 bar at iddling on the fuel pressure line (taken after the fuel filter)
I have 3.0 bar when removing the vacum hose or during the next 5secs I put the ignition on
The fuel pressure is between 3.0 and 3.5 bars under WOT
The fuel pressure is droping slowly continuously a bit after I switch off the car
According to the service manual, these values are ok meaning pressure regulator and fuel pumps are ok
I don't know what to do/test...
The car is fully stock, seems to be in good health (no suspect sounds or lack of power )
Any suggestions ?
Man, adding a Heap of timing is a brave move. I hope there was no WOT action while doing that test
  • 3 weeks later...
Thanks for all your input guys
It looks like the exhaust cam timing is wrong ...(1 teeth off )
However when putting the engine at its top dead center
the admission cam is 0.5 teeth off and so the exhaust cam is 1.5 teeth off
Does it means that the timing belt pressure is wrong which explains the 0.5 teeth difference?
Thanks for your time
On 9/5/2021 at 2:26 PM, bigboss59400 said:
So end of the story
by setting correctly the timing belt everything Line up correctly
The car is now running much better !!!
I couldn't go above 800 degree on medium/hard road drive
I'm so happy
thanks for all
You should probably verify your base ignition timing and do a compression test before you celebrate.
  • Like 1
  • 1 month later...
Yeah I
So to conclude compression test is between 100 and 105psi (full throttle, battery charged )
I always noticed that the high rpm didn't felt powerful
So maybe it has been damaged due to the high temp or not
Anyway it's fine for me at the moment I will leave it as it is
Thanks for the help and suggestions !
    • I am getting the same issue. Did you resolve it? I just got it after installing my new super coppermix and literally the same issue, new fork, new 18mm carrier, release bearing that came with the kit and replicated the exact same sound.
    • If you like - I have the STL files so I can email em. There's a couple of gotchas (i.e the holes are not threaded so you might need/will need) to utilize some M3 melt-in threads for some of the points. However if you want to be super accurate, and are willing to remove your calipers and your SHOCKS it's a really good tool. You also might need to scale the part that measures the tyre width a bit wider. It defaults to a 7.5in tyre and I mean who is running that. Luckily with the magic of CAD this is very easy to rescale.
    • jeebus. glad you weren't under it while performing the stunt. Also thanks for the link to the wheel measurer, exactly what I needed
    • In the older stuff there were very significant differences 2wd to 4wd, for example Stagea had strut front end for 2wd and double wishbone for 4wd so it was not minor to swap. From poking around the 2wd v37, it *looks* like it might be more possible; some of the parts specifically have "2wd" stamped on them which suggests the platforms are more similar. You'd still want to start with a 4wd half cut to swap stuff from though. I'd suggest if you don't have a tune on the ECU you don't really need one on the trans either. Throttle mapping is in the ECU side (and you can always use a Roar Pedal if you want the throttle to actually respond to your foot), and really if you are happy with the stock power you probably accept the stock trans behaviour too....its all made to be "sporty" not racey.
    • So, updates. I have not washed the car since it came back from Tassie. I've driven it around a bit but not got around to actually sorting it out. I DID raise it because I cracked the rear bar leaving a hotel which was very distressing. Interestingly, the car drives more compliant now that it's raised a fair bit (5mm front, 15mm rear). Also noticed that my FR height was 10mm lower than FL. So that's now sorted out, too. I also bought this and had it printed: https://www.etsy.com/au/listing/1576422240/wheel-and-tire-fitment-tool-universal?ref=shop_home_feat_1&dd=1&logging_key=08f604d9fa4cc383550ba985e6ac85cd5cac7fbb%3A1576422240 Now, if I was smart I would have taken my brake calipers off to actually use this correctly but it was evident enough to me that in the region where the caliper was... there was nothing to hit suspension/guard/arm wise. So I'm going with "it'll be fine" after using the tool to hopefully very precisely measure the wheel clearance. Also while doing this, I had the very VERY bad idea of jacking one of the wheels/suspension arms up while the rest of the car was on jack stands. I did this to see how the arm would travel. This all was well and good until the car slid off the stands and went through a fence. So don't do that. Incredibly nobody was hurt and there was only minor damage to the rear bumper as the car didn't have far to slide, and had 3-4 wheels on it. The only damage turned out to be the fence itself which was easy to fix, and a little bit of damage to the fibreglass rear bumper trim. I had already planned to try a touch up paint kit to fix the time I drove into my garage door to see if it'd help in the interim before I get it fixed properly. I used the Dr Colorchip kit after looking online and seeing everyone talking about it. Yes it's made for chips and not huge broken missing pieces and I'll be 500% recommending it for stone chips after using it for stupid things like me. This took about ... 10 minutes and looking at the half assed photo the 30 second job I did on the bumper corner was almost perfect just by using the tiny little brush and painting it in. The sealact stuff to remove over-painting is really useful, so if/when I do it again I'll likely slather the touch up paint well over it and then clean it up with the cleaning solution. The wheels should arrive in a couple of weeks. I am still kinda confident after doing a stupid amount of measuring (and borrowing a set of 18x10.5+15) that they will not fit because I overlooked something, somehow and flew too close to the sun. ALSO R34 GTR guard liners do not fit on a GTT. I bought the undertray brake duct guides and had the wonderful problem of them not fitting my intake, my oil cooler and the liners themselves were even worse. Attempting to fit them won't work in general - You would have to cut them up as another poster mentioned as the bodywork is different on the GTT. At least I can try to resell them. So instead of cutting those up, I cut up my old already-cut-up GTT liners and extended them by using some PP plastic and drilling some 8mm holes for some nissan clips for the 'extra' bit. Because I was happy to cut them I was able to mount them pretty damn forward so I now have some semblance of guard liners, and the brake vents seal the bumper from the bottom. It sort-of-looks like this, to give some idea - If you look at the GTR and then the GTT this is when I realised that I needed to seriously measure as the inside of the rim area is entirely, entirely, entirely different and could not take any internet measurements for granted.
