I decided to make a dual system for the car.....I have bought 10 X 90 degree stainless bends and 6 metres of stailess pipe to do the job....i may need to get some more bends but what i have will get me started....I have also bought 6 dual pipe flange plates and 2 catalytic converters and two mufflers......the pipe size is 2 1/2 inch....first part of the job is to bolt the flanges on the turbo dumps and cut the bends up to make the front pipe,then we tig weld them all together....heres a few pics of the front pipe being made....
so is this going to be like 350Z style? or Just the standard R34 GTR exhaust, but fatter twin pipes? Looking good so far, and your car looks soooo shiny! I'm guessing the paint job came out rather well :rofl:
ooo, you got the front/rear bumpers on, ready for the line up yet?
cheers.
Woah ho! Looks like all the panels are on the car again! :rofl:
The piping is looking good, Troy. I'm thinking of doing my own front pipe as well hehe (don't know how bad it will turn out, but going to give it a go). Just a few questions,
1/. Where do you get the flanges from? or are you using the old flanges plate? Does it matter if the size is different from the flange and the pipe? (ie flange 2.5inch to 3inch pipe)
2/. Is there alot of chance of air leaking from the welded area? (i'm a beginner and ther is no ways I can do a as good welding job as you hehe) and does it matter if it does leak?
Not sure what you mean by 350Z style..... I will post more pics of the system as it get fabricated....i think we should wait untill you get your car...then we will do the match up as i am not to keen on playing with same one elses bumpers(neither would they be :rofl:)...dont worry too much about it chinny...we will get them to fit nicely......Aaron....personally i would be using new flange plates and make sure they are the same size as your pipe....having said that if your dump is x size...then it should be that size......make sure your welding them with a Tig or at least a Mig welder....If using a Mig turn your wire feed down as low as possible and the current as high as you can get it without burning a new arse in the pipe....and make sure your cuts and joins are a tight/butt up fit to each other....use a drop saw or band saw to cut the pipes,this way the cuts will be true to each other.I would try to avoid using a Mig for pipes....the only Mig welder i used that would be suitable for a top notch finish was a Migtronic brand....I have to say this thing was awsome.Its activation switch was a micro switch the gave a 3 second delay between wire feed on the initial push so it would purge the job with argon before it striked,then once it striked you had a wire feed speed knod on the torch so you could feed more wire or less wire depending on the gap between the pipes...however it cost the guy 8 grand....a small Inverter such as a Caddy Tig can be bought for about 1500 new from BOC....oh and aaron,make sure you weld it properly,we wouldnt want it to leak...just have a go on a few peices of scrap first
hehe yeah I think I will have a go at scraps first haha
Where do you get new flanges from Troy?
Use cat plates from a VN commodore......get them from an exhaust place....alternatively you can cut them out with a plasma cutter
Very talented man indeed.
On a side note is this the car that I saw stripped outside a certain panel shop for a few weeks on the same road where I work? ( western suburbs> somerville> duty ) The brackets will make sense if its you.
almost finished it today......I got the rear muffler section finished,dummied it up and started it.....sounds like a superbike :P....still have to make up the hanger brackets....Due to the complexity of the lower suspension rear under body diffuser its a very tight fit i might rework one of the pipes over to the right side of the vehicle and back under the spare wheel well to stop it being so vulnerable.....heres a pic of the rear muffler unit that i made today....And yes that was my car at onduty panels on sommerville rd....i am suffering from severe TIG UV sunburn now so i am going to chuck some afterburn lotion on :)
    • That is surely the biggest gathering of Stageas in North America, ever!
    • Remember kids - if you can't afford to buy 2 GTRs......
    • I know people cry at the price of the Getrag 12-14k for a conversion now, but it really is a nice mid point. Not going to get change from 10k on a gearset installed.  $30k++ for sequential.   I know you run the risk of a damaged used one and parts are hard to get but as a street car gearbox its really hard to beat. If you enjoy a more traditional manual, its the choice no question.
    • Time to decide what’s more import, your power level or your budget because you’re going to struggle to keep both
    • Our Southern Highlands Cruise is proudly registered with “R U OK?” Day.  Sometimes the best way to check in on your mates is by getting out for a drive together. Sharing a common passion like cars creates the perfect space to chat, connect, and support each other.  A simple “R U OK?” can make all the difference. Let's enjoy the drive, the company, and look out for one another. PLEASE WEAR YELLOW FOR “R U OK?” DAY Sunday 14th September 2025 9:30AM Meeting Crossroads Homemaker Centre 10:00AM Cruise Departure Via Old Hume Hwy 11:45AM Arrival at Mittagong RSL Club Meet Location: Crossroads Homemaker Centre Final Destination: Mittagong RSL Club *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
