R33 gtst Do-Luck chassis bracing kit. This looks like a roll-cage but isn't, it serves the purpose of stiffening up the rear part of the car. Same thing as this http://www.jdmautolink.net/2019/01/do-luck-rear-tension-set-bcnr33bnr34-05.html
 In my discussions with a Senior Inspector from Qld Transport, this does not require certification/mod plate as per his email " In reference to your Rear Tension Set I have done some research and I agree that it is not ROPS and as long as it does not affect the ability of the vehicle to comply with an acceptable level of occupant protection and comfort therefore with the padding you have applied and providing the device does not obstruct passenger access or headspace then I see no issue. "
It is LIGHT so, can post anywhere in aus at your cost, or pickup in Brisbane.
$375 + any postage cost, I estimate around $30-40 to most delivery areas.
  • 1 year later...
bump, to $300...just gathering dust here. Also have>
Craig Davies 16-inch thermofan on fibreglass shroud to fit an R33 gtst radiator, and Craig David electronic fan controller with wiring harness ready to fit to R33. $165 plus postage to most places in Aus. Very very new. Note if you like in a warm climate like Qld you'll struggle to control temps in a streetcar with a thermofan, OEM is best, but should be fine in colder climates or track car.
GTX3076Rg2 Garrett turbo, and Hypergear ATR43 ballbearing turbo.  $1200 and $1000.
  • 4 months later...
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
