Firstly is it even the diagram I should be referring to ?
My model year is 1990 gtst
If yes, pin 8 in this diagram is the final variable voltage as per speed going to the solenoid? And also it goes to the consult port for the what ?
I mean that’s what it looks like, but I am not to sure if it could be going to elsewhere?
Also pin 5 says to ecu I have color matched that wire (brown with silver trace dots) it is wire to one of the connectors that engine/ecu harness connects to but the ecu side of that wire has been chopped so don’t know where that should be on the ecu or can I connect this directly to speedo wire going to pin53 on ecu ? It makes sense to me unless ecu is pulsing that signal or is that signal from speedo already pulsed ?
my only hopes are with you @GTSBoy🙃
also is there any proper wiring diagram on here that could help me
The ECU doesn't create the speed signal. It is created at the speedo head. That signal is available to all the CUs on the bus that want it (ECU, TCU, ABS, TCS, HICAS, ATESSA).
On that diagram, I can only assume that the "High speed sensor" is the speed sensor/transmitter in the speedo head, and you can see that that wire reports to both the ECU and the HICAS CU on terminal 6 (I think it's 6 - on the RHS up near the top).
The other wire "to ECU" on T5 must be for some signal from the HICAS to the ECU for some other reason. It might be something to do with PS load idle up, or god knows what else.
  • Thanks 1
I am starting to think it could be your speedo.  I had the exact symptom as described in the flow chart I posted when my speedo cable broke, and my HICAS was untouched.  Is there another GTST local to you that you can perhaps borrow the cluster to test?  It's a fairly quick swap.
It could be, I am yet to check if I am getting a pulsed signal at wire going to pin 53, as in past I took my speedo out, the small device(speed sensor)that creates this signal behind the speedo was all intact and fairly in good condition including wiring and the I did a continuity test from there to wire going to pin53, will update once I have confirmed that. I have been assuming my speed sensor is good I could be wrong though.
And I now think hicas could be getting the speed signal independently from the speedo.
  • 9 months later...
I have a new r33 reservoir 8n ky R32 which means i no longer have the reservoir with oil level switch. Im guessing thats why my steering is now heavy?
Sigh, now to trace all the damaged loom back to find the wires for reservoir cap with level switch
Yeh. I have looked at the wiring diagram but doesnt appear as though it is the absence of the level switch that is causing the problem. I am waiting for a mate to pull the plug on the cap and go for a drive. I suspect there is something else astray which is why I reckon I just need to go through all the wiring and see from there. The two obvious ones are the speed input and the actual PS solenoid. Maybe with the engine going in and out and all the fluffing around with oil cooler lines/Accusump etc its been pinched. I don't know. For now I am just channelling my inner 18yr old ex Valiant owner
3 minutes ago, Duncan said:
Most often speed input....is your speedo working....those cables like to break after all this time.
Yep, stupid things snap right at the back of the speedo where it changes to plastic. I'm surprised no one has made a fully metallic replacement cable by now.
On 11/1/2022 at 1:33 PM, Roy said:
It could potentially be that r33 ps pumps have lower pressure??.
No.
I will recount my old story where the power wire for my O2 sensor shorted inside the loom and burnt the wiring for the PS solenoid - giving me 100% dead heavy steering. Loom faults are defo a thing!
    • Did this end up working? Did you take some pictures?
    • And finally, the front lower mount. It was doubly weird. Firstly, the lower mount is held in with a bracket that has 3 bolts (it also acts as the steering lock stop), and then a nut on the shock lower mount itself. So, remove the 3x 14mm head bolts , then the 17mm nut that holds the shock in. From there, you can't actually remove the shock from the lower mount bolt (took me a while to work that out....) Sadly I don't have a pic of the other side, but the swaybar mounts to the same bolt that holds the shock in. You need to push that swaybar mount/bolt back so the shock can be pulled out past the lower control arm.  In this pic you can see the bolt partly pushed back, but it had to go further than that to release the shock. Once the shock is out, putting the new one in is "reverse of disassembly". Put the top of the shock through at least one hole and put a nut on loosely to hold it in place. Put the lower end in place and push the swaybar mount / shock bolt back in place, then loosely attach the other 2 top nuts. Bolt the bracket back in place with the 14mm head bolts and finally put the nut onto the lower bolt. Done....you have new suspension on your v37!
    • And now to the front.  No pics of the 3 nuts holding the front struts on, they are easy to spot. Undo 2 and leave the closest one on loosely. Underneath we have to deal with the wiring again, but this time its worse because the plug is behind the guard liner. You'll have to decide how much of the guard liner to remove, I undid the lower liner's top, inside and lower clips, but didn't pull it full off the guard. Same issue undoing the plug as at the rear, you need to firmly push the release clip from below while equally firmly gripping the plug body and pulling it out of  the socket. I used my fancy electrical disconnect pliers to get in there There is also one clip for the wiring, unlike at the rear I could not get behind it so just had to lever it up and out.....not in great condition to re-use in future.
    • Onto the rear lower shock mount. It's worth starting with a decent degrease to remove 10+ years of road grime, and perhaps also spray a penetrating oil on the shock lower nut. Don't forget to include the shock wiring and plug in the clean.... Deal with the wiring first; you need to release 2 clips where the wiring goes into the bracket (use long nose pliers behind the bracket to compress the clip so you can reuse it), and the rubber mount slides out, then release the plug.  I found it very hard to unplug, from underneath you can compress the tab with a screwdriver or similar, and gently but firmly pull the plug out of the socket (regular pliers may help but don't put too much pressure on the plastic. The lower mount is straightforward, 17mm nut and you can pull the shock out. As I wasn't putting a standard shock back in, I gave the car side wiring socket a generous gob of dialectric grease to keep crap out in the future. Putting the new shock in is straightforward, feed it into at least 1 of the bolt holes at the top and reach around to put a nut on it to hold it up. Then put on the other 2 top nuts loosely and put the shock onto the lower mounting bolt (you may need to lift the hub a little if the new shock is shorter). Tighten the lower nut and 3 upper nuts and you are done. In my case the BC Racing shocks came assembled for the fronts, but the rears needed to re-use the factory strut tops. For that you need spring compressors to take the pressure off the top nut (they are compressed enough when the spring can move between the top and bottom spring seats. Then a 17mm ring spanner to undo the nut while using an 8mm open spanner to stop the shaft turning (or, if you are really lucky you might get it off with a rattle gun).
    • You will now be able to lift the parcel shelf trim enough to get to the shock cover bolts; if you need to full remove the parcel shelf trim for some reason you also remove the escutcheons around the rear seat release and you will have to unplug the high stop light wiring from the boot. Next up is removal of the bracket; 6 nuts and a bolt Good news, you've finally got to the strut top! Remove the dust cover and the 3 shock mount nuts (perhaps leave 1 on lightly for now....) Same on the other side, but easier now you've done it all before
