I'm in the middle of installing a few Haltech bits and can't find a nice place under the hood for my TCA-8 amp. Where is everyone putting them? I hate that they put the connector on top.
What length leads did you get on your EGT's?  I've got the amplifier but not the EGT's yet as I want to confirm where I put them first.  My plan is to either put the amp next to the ECU somewhere or if there's not room there or will make too much mess with wiring into the cabin I'll be putting it inside the passenger side (left side) front guard.
I bought WHP thermocouples from ecumaster. They are much cheaper then Haltechs and come with weld bungs and compression fittings. Not certain how long the leads are, but long enough to get anywhere sane.
Haltech states the amps are not completely water proof so I'm going to avoid front guards. I don't want to put it in cabin to avoid the nest of wire. Rather pass 1x canbus cable into engine bay then 6x TC's into cabin.
On 4/25/2022 at 7:22 PM, r32-25t said:
I’m thinking of putting mine either behind the abs unit or in the passenger guard
I have a catchcan where abs usually is, if not that would of been a great spot. I'll probably make a bracket and put it somewhere in that region.
Do you not have wheel arch liners?  It should be pretty well protected back there.  Can pretty easily waterproof it if need be.  Wrap it in a plastic bag.
Throughout my career as an electrician and then an electrical engineering technologist, I have yet to see a plastic bag wrapped in electrical tape waterproof anything. It has the opposite effect, water gets in and stays in.
I agree, It should be rather well protected with liners, but I like to err on the side of caution.
Hey, I'm no rocket scientist or electrician but I do know water doesn't flow up hills very well.  If you affix it vertically with the cables coming out of the bottom of the sealing bag (like one of those waterproof phone swimming bag thingies), the insignificant amount of water that gets passed your guard liners isn't flowing up into the bag provided it's half well sealed.
But anyway, your car, you do what you see fit!  🙂
It can actually flow up into it. Capillary action up the cable into the bag.
I appreciate the ideas though. Sorry to come off strong, bagging things is just a very hot topic in my field. A lot of old timers did it and it's one of those things we scream inside when we see because we know when we remove it to do it properly, you'll get covered in rusty water and whatever surprise it hides will be corroded.
Cheers!
Aren't these small enough that they could reasonably fit on the front side of the passenger's suspension tower? Where the PS reservoir and airbox live. A little judicious relocation of the loom plug that resides there should see enough space made.
Or how about on the firewall above the ABS unit?
Unfortunately with the Type K connectors at the bottom and the canbus connector on top, you need a fair amount of space. I tried both locations you mentioned with no luck. I'm either going to make a bracket to space it out near your yellow circle or near the right headlight.
Cheers.
  • 6 months later...
  • 4 weeks later...
On 11/19/2022 at 2:47 PM, bigboss59400 said:
I would be interested to know what did you do at the end ?
THanks
I'm a tad late to the party but here's where I ended up installing it. One oem hole, bracket to another oem hole I also use for PS reservoir.
I used a 90Deg strain relief instead of the straight supplied on the 8pin connector.
Cheers.
  • Like 2
1 hour ago, bigboss59400 said:
THanks for the update !
Do you still have the ref of the angle connector ?
Best regards
TE Connectivity Part #'s. Cheers.
Angle Connector: 1546347-2
Connector Pins (If ever you scrap one depinning): 66506-9
Depinning tool: 91285-1
  • Thanks 1
    • Can't you put the pistons to TDC and then do the valve seals? Or will the drop down too far to pull them back up?
    • One thing I can tell you is, do it properly the first time. If you encounter unexpected problems just let the car sit for a week or two if you have to get some other parts or figure stuff out.  I'd have said go and use as many OEM parts as possible but since you want to change the turbo later on a custom kit is probably the better choice. Since I have no experience with RB25 just compare parts diagrams and images before buying a line kit and it should be easy to see if it has everything you need. Amayama has very good parts diagrams and part number lists, that is what I used a bunch to figure out what I might need. And don't forget to plan ahead and possibly renew other stuff that's easy to get to while you're in there doing the turbo lines. Happy wrenching
    • Update 4:   Hi all, good news. Engine is running and all the gaskets and seals seem to be working as intended. No leaks so far, even the JB Weld seems to hold. I flushed out the old coolant a few times and put in fresh coolant, not Nissan stuff, I decided to try the Ravenol Protect FL22, they claim it works for a wide variety of JDM cars and the opinions on it by some people were pretty good. And it has the nice poison green color! And man am I glad I bought a coolant system tester earlier this year, vacuum filling works wonders on this engine. I can definitely recommend this to anyone still doing it the old school way. All you need is compressed air supply. Will have to do a small test drive as soon as I can, I removed the gauge cluster again as the tacho needle was still bouncing around a bit but it was much better than before already.  I also found some cracks on all 4 tires inner and outer sidewalls. Apparently these tires should 't be parked on for extended periods or be kept under 0 degrees during storage, which I did not know. Clearly the previous owner didn't look into those details either, he probably bought them just cause they are cool semi-slicks. I'm just wondering how tf I am supposed to reach 30-80 degree tire temperatures on the public road consistenly, these tires were never going to work for my use case. I'll probably order Continental SportContact7 ones as these are the best allround summer tire available right now and I don't think I'll need anything crazier for now. Do let me know if you have experience with various tires and which ones you recommend.
    • You have no idea how many goddamn boxes I received these past three months haha Most have been put to use by now though, luckily
    • Not going to pretend I didn't do a bit of junky work this time around, but mostly due to the fact that some things I am not willing to spend days fixing right now, like wiring. I try to do most things properly the first time around.
