V35 Saloon VK45DE build
R34DE as in R34 with an RB25DE? So did you get this? Or you planning to?Β I'm not really sure what you're saying.Β
1/8NPT drill size = 8.7mm. Since the hole got messed up by me, itβs probably around 9mm.Β Β So 1/4β NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)Β
