just got around to doing an auto to manual swap in an r34 gt to gtt manual box, auto dash shows N in neutral and reverse in reverse lights beeps, speed, rpm temps etc all work.
BUT now brake lights semi work and don't work. The furthest left light and the high brake lamp work, the other 3 are permanently on, no idea if these 3 run off a different circuit? Makes no sense but ill probs try anything at this point lol.
Edited by hugh jaynous
spell check
It is not directly caused by the swap. You may well have broken something during the swap, but the swap itself is  not the cause.
The most likely cause is the brake pedal switch. You would have had to be stuffing around in the footwell to fit the clutch pedal, so....there's how you break something. The pedal switch will be stuck on, feeding all 4 lights. The reason one of them is not working will be because of a broken globe, or a faulty earth at that light, not because of some magical thing capable of creating a single fault that makes only 3 out of 4 come on.
The brake light circuit is about the simplest circuit on the car. Break out the wiring diagram and a multimeter and start finding the fault.
  • Like 2
i guess to clarify the explanation a bit, all the lights light up, but only one brake light + high lamp is properly functioning ie; when off the brake pedal and the pedal switch is fully pressed down in contact with the pedal that one light is dimmed while the other 3 show no change as if im still stepping on the brakes. I'll try to poke around with a multimeter now, but if by some stroke of genius there's some other thing possible missed im all ears, thanks!
Sorry, I should have read the OP more thoroughly. Sounds like you could be backfeeding the circuit from somewhere, which shouldn't be an easy thing to do if the wiring is original and unbastardised. But because it's a 25 year old car and you've just done a modification that includes messing with the wiring loom, it is actually best to describe it as bastardised and proceed accordingly. Proceeding accordingly would be to presume that your fault is unique to your equipment and diagnosis from afar/past experience will be unlikely to just give you the exact thing to look for. It always turns out to be something f**ked up that was completely unexpected.
The method is still the same. Grab wiring diagram and multimeter, screw on the thinking cap, and start diagnosing where power is (and should be and shouldn't be) and where it isn't (and should be and shouldn't be), with the switch open, closed, globes in and out, at earth points, etc, etc.
ah....i never thought about this, since i just snipped the two auto connectors and spliced the 3 wires to neutral/reverse/inhib and then taped the other cables back without making sure they didn't touch another cable, potentially some of those cables are actually contacting each other now.
    • Given you're running a 2.8 and my 2.5 is not really like for like, I suspect there could be a bit more timing you could give it. What is the kW yield per degree you're putting through it? Here's my E85 map to give you an idea, where it was I could still get another 3~4kW per degree thrown at it.
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
