Hi all
I have been searching around for an aftermarket Intake Manifold (FFP)
Wanted to see if there are any others out there as i have been searching for a few months and find a new one every week or so.
Overall Height will be the main concern (cant be much higher then Valve Covers). will be in 300zx Z32
Would like to stick with Long / Medium runner If possible. I may be able to do a cut and shut on the OEM one.
Plazman Top half
May be an option but could sit to high
Hypertune
short runner
CPC
Short runner
Greddy / Freddy
tried and true short runner
Speedtek Racing
Cast Aluminum 2 piece short runners
Rajab Racing
Top half, sits high currently only RB30 but in testing prototype for RB25 as of May 25
IMR Fabrication
plenum/runners welded to Oem flange look nice may be an option
China/ZERO Fab / ISR / NP Bosted
short runners
let me know if there are others out there that may fit the bill!
https://www.sau.com.au/forums/topic/483738-rb25-intake-manifold/
Assuming you have horizontal space in the engine bay, any of those replacements that don't use the lower factory runners would be OK, wouldn't they? I run ebay china spec in my rb25/30 stagea. Also I am not sure how you (or the market) define long and short runners, in those pics there is a big variation. The length in mine looks visually similar to your last pic.
Of course, there is no science in my response; the bottom end torque is very drivable in my setup but it is a manual rb30 not a 25, and I don't have back to back dyno runs with factory runners so it may be worse down low than stock.
BTW if you are pushing the engine you will want individual cylinder o2 or temps when you tune. You can see visually that there is no way that all of those different designs will end up with the same air flowing into cylinder 1 as cylinder 6.
Also, keep an eye on clearance to the clutch master (particularly if it is boosted) if you go with a cast FFP.
Agreed,
I guess I would consider long runner oem or rajab since they have their own runners and they bolt to the oem lower
plasman (top half cap?) Mid length (just a collector that uses oem lower)
and all the rest short runners
I'd be close to 200% sure that there is no long/medium runner length option that you would want to use. That IMR manifold looks interesting (although, why the living f**k did they think they needed to lobsterback it together!!!???!! Just stupid!). But I'm pretty sure that there would be compromises wrt ancillaries and so on that you'd not like to live with. Getting to the stuff that lives under the manifold will be harder, and it's already hard enough. Plus, the alternator access looks less nice.
So, that leaves the shorter stuff, and if I had to go down that path, I'd just suck it up and pay for Hypertune.
    • So..... it's going to be a heater hose or other coolant hose at the rear of the head/plenum. Or it's going to be one of the welch plugs on the back of the motor, which is a motor out thing to fix.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
