  • Replies 47
Never heard of this company Grex, and it seems to me that 2.7 is done more by bore than stroke (cant rember stock rb26 bore).
From a recent discussion on another forum i understood that a 2.7 wont give that much extra power really, but if you are doing it to keep safe then it would be good.
but grex..... hope they are not releates to MotoRex in the usa
That price is just for the pistons, doesnt include the conrods or crankshaft that come in the higher priced ($10,000+) kits.
And yes, Grex is Greddy is Trust etc. They are the same company, but technically they are different.
is it worth the price tag
http://turbulence.com.au/shop/product_info...products_id=135
i thoguht they would be more expensive then that, can anyone confirm if the kit is any good
MrChams is running the Trust 2.7 kit in his R32
I sure am... there are different kits from what I understand.
The kit that I have is 87.5mm GREX pistons and GREX H pattern rods.
The larger 2.7ltr piston kit helps my Greddy T78 spool up quicker.
Due to the cost of after market cranks, I am running a standard crank that has been shot penned and cryogenically treated (dunno what the hell that is but hey...)
The standard cranks are pretty strong. Before my rebuild this crank held 720hp with no signs of breaking. Not sure what there limit is.
I'm still running in the engine. Once I have it tuned I'll let you all know how I went for power.
The kit on the link above is just the over sized 87mm piston kit.
This is not the stroker kit.
The piston size makes it 2.7ltr.
My pistons are 87.5mm not 86.5mm. Typo
If you check out this link, you can calculate the displacement
http://www.benedict.esu7.org/sblock/ccfrm.html
It's something like this (don't quote me on it)
Bore radius squared x pi x stroke x no. of cyl = Total cubic displacement
How do you get the extra stroke necessary for 2.7L from a standard crank and 86.5mm pistons? :confused:
how much difference? Just outta interest.
And running in an engine? Thats over-rated in this day and age
Ahhh okay...
Std bore & stroke (86x73.7) = 2568cc (juuuuuust enough to claim 2.6 Litres :P)
87.5mm bore & std stroke = 2659cc (also juuuuuuuuuuust enough to claim 2.7 Litres :))
Did you do these internal upgrades by themselves? Could you really tell the effects of extra 100cc capacity? Or did you do other things like camshafts, cam gears, etc etc at the same time?
The stoke on the trust piston is 75.7mm and the piston size is 87.5.
Regarding the mods etc,
It's not just the pistons that has given the improvement but extensive head work.
The head work included modifying the bowl shape, different angles on the valves and valve chamber, valve guide modified, cam area opened for bigger cams and the obvious port enlargement.
I am currently running the standard cams with adjustable cam gears.
Bigger cams will be fitted soon once I decide what size to get.
Yes, I did notice the difference. The engine does feel like it has more down low torque but I can't say till we tune it on the dyno.
Ahhh okay...
I don't agree with not running in an engine.
My mechanic use to work for Nissan Japan.
They did test on how to run in RB engines. He told me that the best result was when they ran the engine up to 4,000rpm for the 1st 1,500km then oil change then up to 5,000rpm to 5,000km.
He told me the bore was perfect after such a run in.
The test also involved using mineral based oil in some engines and full-synthetic in other engines.
The full-synthetic oil run engines came out much better.
The price is very high just for Greddy pistons.
You should be able to get the pistons for approx $2500 and the rods for approx the same, $2500...
damn, when i saw the pic and the price i already got the credit card out, but for pistons only hm doesnt seem worth it,
How exactly do you increase stroke by 2mm with a piston upgrade on standard crank? :confused:
And I don't need a web calculator, I remember my Year 7 volumetric formulas :Oops: Probably the first time I've used them since high school :)
5000km run-in??? That would take most people 6 months to complete. You really think that's a feasible run-in time?
What engine parts could POSSIBLY need 5000kms bedding in time??? :uhh:
No comment on the full-synthetic running in oil use... People have different ideas on that one, but the vast majority believe that mineral oil for the first 1000kms or so is still the best way to go.
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
