On 8/4/2022 at 10:50 PM, SLIXK said:
Anyone know if the hks cam gears that fit the gtrs work on the neo stagea, I’m changing my belt and want to get gears at the same time. Stagea isn’t in the stated compatibility list but the heading is rb 20,25&26. The tomei cams on the other hand stagea is listed.
The NEO engines have VCT on the intake cam. So unless you delete that whole oil-fed system you would need a different intake cam gear to be able to vary the intake cam timing. Keep in mind you must test the system at both extremes unless you want to potentially let pistons meet valves when the cam is advanced. Exhaust cam should be the same either way.
  • Like 1
https://www.sau.com.au/forums/topic/483917-hks-cam-gears/#findComment-7968626
So would Tomei gears work with neo vct
https://www.sau.com.au/forums/topic/483917-hks-cam-gears/#findComment-7968629
On 8/5/2022 at 3:57 PM, SLIXK said:
Okay I understand now, there’s no need for adjustable cam on inlet but I can do it for the exhaust side. I really just wanted it for looks. Now I’m rethinking because I’ll only have one after market cam gear now on exhaust side…
Priorities. Priorities. Pretty pretty priorities.
https://www.sau.com.au/forums/topic/483917-hks-cam-gears/#findComment-7968634
On 8/5/2022 at 2:28 AM, SLIXK said:
How sick would it look tho, might just get exhaust gear, still, does anyone know if it hks one works with stagea?
If this is a purely aesthetic thing I recommend not bothering. Multiple times now people have forgotten to torque + threadlock their cam gears to spec with the correct timing and they've trashed their heads when it loosens and allows cam timing to hit the extremes of advance/retard.
https://www.sau.com.au/forums/topic/483917-hks-cam-gears/#findComment-7968644
Okay, I’ll just get a HKS belt at 100ks then and clear timing cover 😎
https://www.sau.com.au/forums/topic/483917-hks-cam-gears/#findComment-7968645
On 8/7/2022 at 9:18 AM, joshuaho96 said:
Clear timing belt covers can be useful, someone local to me recently discovered their timing belt was hanging on by threads because of it and got a tow home instead driving home and snapping it entirely.
That's not useful. Timing belts last absolutely ages.
https://www.sau.com.au/forums/topic/483917-hks-cam-gears/#findComment-7968683
On 8/7/2022 at 9:45 AM, joshuaho96 said:
Not if the timing belt somehow is misaligned upon installation. How someone managed that I'll never know but that was one time where the clear cover paid off.
It doesn't surprise me that the type of person who wants a clear timing belt cover is the type of person who can't put a timing belt on.
  • Haha 2
https://www.sau.com.au/forums/topic/483917-hks-cam-gears/#findComment-7968686
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
