Hello, first time posting here.
I'm after new suspension for my R34 n a 1998 Skyline sedan.
After doing some investigation underneath a hoist I have determined that my rear suspension is using the eyelet configuration.
When browsing for coilovers. They all seem to have rear fork style configuration.
I have seen some comments that the R33 GTST suspension will work on the R34 NA sedan suspension?
Is this correct
Edited by RB25inside
Photos
https://www.sau.com.au/forums/topic/484059-r33-gtst-suspension-on-r34-na/
Coupe and sedan are identical. They are identical cars mechanically (R34 coupe and R34 sedan) with the only exception being the exhaust.
R33 GTST brakes and suspension will fit on a R34 NA.
I do not know whether there's realistically any damping differences in some companies setup but I HEAVILY doubt there would be, if looking at something like a R33 GTST BC coilover and a R34 NA BC coilover, or a R34 GTT BC coilover for example.
Cheers for the message ☺️
BC Racing looks really good especially with the damper option. But I don't really have the money for them...
I know it's like half the price but have you heard of max speeding rods before?
https://au.maxpeedingrods.com/product/nissan-skyline-gtst-r33-24-way-adjustable-damper-coilover-shock-absorber-strut-suspension-kit.html
Yep, they are bad. Theres a reason they are cheap and poor man pays 3 times.................
Better off getting a lowered spring and shock replacement or save a bit longer and get MCA or something that is actually valved decently for street use.
  • Like 1
Yes. If buying (coilover) suspension these days, it is foolish to do anything other than buy MCA or Shockworks (Shockworx?) in Australia. Properly specc'd, quality controlled, locally dev'd & supported. A better decision than random D shift stuff out of Taiwan or China.
  • Like 2
What is your reason for getting a set of coilovers?
If your reason was for sure 100%, "I just want to lower the car" and you don't care about, ride quality, performance on road, performance on track, etc. Yes, you could go with cheap China coilovers, they will indeed lower the car.
If I was strapped for cash and wanted to lower my car, I would get custom king springs with the spring rate and drop that I want. Fit the springs yourself and keep saving up the $. Then I'd buy a set of good Koni shocks and take everything to a good suspension place that has a shock dyno. They can valve the Koni shocks to match the spring rates. When I was a young lad I did this exact process with my turbo swift, I found that custom king springs cost the exact same price as of the shelf stuff and getting the Koni's revalved was about $80 per shock. This might have been about 15 years ago now but surely it can't have gotten much more expensive then that.
  • Like 1
Current suspension is shot (It is making gun shots noises rattata) I have isolated it to the front to shocks. The rear two are ok. The whole car is running stock suspension currently.
I just brought the car but it needs to be replaced asap.
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
