Hey everyone, I'm currently working on my project car and I'm in the middle of doing the cooling system. The car does not have a fan clutch and I have ordered the GKTech fan with the adapter for better cooling.
However, when I ordered a brand new dayco fan clutch the GKTech adapter doesn't fit it. Has anyone else been able to find a brand new fan clutch that works with the GKTech adapter/fan? Car is a series 1 R33.
I have tried these fan clutches:
- 115847
- 115836
Both dayco branded.
Link to the adapter if anyone wants to see it. https://au.gktech.com/rb-vg-clutch-fan-adapter?utm_source=googleshopping&utm_medium=cpc&utm_campaign=googleshopping&gclid=CjwKCAjwh4ObBhAzEiwAHzZYU9RnrCnUm0PUXcNNXp656f03U5Nk0TR16TZWsUssVIm3A-2AXVM5hxoCN9YQAvD_BwE
Thanks in advance!
https://www.sau.com.au/forums/topic/484171-series-1-r33-gtst-fan-clutch/
3 hours ago, Disco18 said:
And I have ordered the GKTech fan with the adapter for better cooling
No. No. No. No.
Point 1. The GKTech fan works well on SRs. It is no good on RBs. Get a factory fan.
Point 2. You need an adapter to fit the GKTech fan to the RB clutch. That's because of point 1. It is for SRs, not RBs. But it doesn;t worj anyway, so see point 1.
Yeah, good luck with that. My experience is that the Dayco clutches are no damn good either. Too noisy. Get OEM.
So, all in all, a complete fail. Abandon all that you have and have done, and spend the $500 odd it costs to get proper Nissan stuff.
  • Like 2
1 hour ago, GTSBoy said:
No. No. No. No.
Have you seen examples of that fan not working on RBs? Why would it be substantially different on the different motor?
Not personally. Only going on several other 1st hand results posted on here (and in the UK, I think?). IIRC, my bro-in-law, who is an import workshop owner, has several dorifto customers with them on RBs and they all overheat on the road (although most of them have no shroud, which definitely contributes). It's been some years since I formed these opinions and draw these recollections. It's really only the outcome that remains, not the source material, if you know what I mean.
That fan is intended to be for dorifto flatbrims. I think that fan actually moves less air than the factory SR fan. It's about unloading the engine and reducing the noise/power draw (for the flatbrims). It's actually no surprise that the stock RB fan can move more air. The blades on the GKTech fan are rather small.
  • Like 1
Fair enough, thanks for the input. I guess I'll look into people who have used the fan more because I haven't really heard anything bad about it and if it is as garbage as you say I'll get stock fan and a aftermarket fan clutch because $450 for a oem fan clutch is a tad to pricey for me haha
You can always hit up the local wreckers. I grabbed a good 2nd hand stock fan setup from Skyline spares a few years back now, can't remember how much it was so it couldn't have been that expensive, everything has been perfect so far.
  • 3 months later...
- 115847
- 115836
Both dayco branded.
Thanks in advance!
I ordered a Dayco fan clutch (115836) and it’s nothing like the OEM one I need to replace.
PCD of holes don’t match, height and overall diameter!
what’s the correct one for my series 2 r33 gtst?
  • Confused 1
It's not the Dayco, whether it fits or not. Buy a Nissan one.
Lol....man I was literally in this mess not long ago.
Ended up returning the Dayco one and getting an used OEM one.
And GKtech fans do no work well, I've ripped 2x of them out of S15s with cooling issues and went back to OEM.
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
