Colour me confused. How can you remove the dampener to see what the idle pressure is? I feel that you are confusing the wording or the physical location of these devices. The dampeners are upstream (and perhaps on) the rail. The reg is at the outlet of the rail and is the very last physical device in the fuel system other than the return line to the tank.
Do us a favour. Locate the real, actual pressure reg. Remove the vac line from it and tell us the idling fuel pressure then.
  • Like 1
Dampener is after the fuel pressure regulator on the rb26, removing the vac line changes the idling by like 0.05 bar or something like that
If it satisfies you I also ran the car with the hose right off the fuel pressure regulator as stated and nothing changed
The dampener would do nothing if after the regulator. What would it dampen?
Taking the vac line off the reg at idle MUST show an increase in pressure. That's how referenced regulators work mate. If it's not doing that it isn't working.
Or you have the vac source plumbed wrong. Can you feel a suction on the vac line when disconnected at idle?
Isn't the stock RB26 fuel damper in the return line? That's how I read it here:
271961703_ScreenShot2022-12-10at12_28_13AM.thumb.png.46c588e0be556871ab4b5ba08de2b778.png
I agree that something is wrong if pulling the vac line only changes the fuel pressure by 0.05 bar. Look at your manifold pressure in absolute pressure. If your idle is -20 inHg then assuming your base pressure is 4 bar it should drop to 3.32 bar with the vacuum line plugged in. Are you sure your vacuum line is plugged in at the front of the balance tube? I have heard of people mixing up the charcoal canister vacuum line for the FPR vacuum line.
It’s plumbed like this
2 minutes ago, joshuaho96 said:
That's the correct port, not sure why your fuel pressure is behaving weirdly then. You sure it only changed by 0.05 bar and not 0.5 bar?
I will check again tomorrow, could I have a pretty bad vacuum leak somewhere in the surge tank or something
No. Is there a strong vacuum signal on that vac line on the pressure reg when you pull it off? If there is not, suspect the source. If there is, then suspect the reg. But something is defo f**ked.
  • Like 1
Change in real world is generally 3 - 4psi. 40 psi at idle full vacuum, 43psi at 0 vacuum with line pulled. Bar talk at this level is silly. 0.5bar change I would not expect realistically, that's a bit dramatic of a change at 7.5 psi and 0.05bar is basically no change.
I was just going by the book value mentioned earlier. Wouldn't this depend on the particular slope/response of the fuel pressure regulator? I figure the goal at idle is to drop fuel pressure so you stay deeper in the linear regime of the injectors.
When I upgraded to a radium FPR, with the vacuum line pulled, base pressure is 43.5 psi. With the vacuum line back on, the pressure drops to 33.5 psi.
Big difference between the stock FPR and the radium one for sure.
21 hours ago, damnonrs said:
So I dove into the fuel system today,
I removed the line coming out of the damper and plugged it into a fuel canister. The idling pressure dropped from 4.25 idling to 4.05 steady. I’m assuming the 5% improvement is because of all the twists and turns tk get back to the fuel tank. So damper isn’t the problem. But then I also tried plugging it straight from the regulator and it was the same thing. All that’s left to test now is regulator itself or the rail… which brings me to: do I buy a radium fuel rail with damper and fuel pressure regulator in one? Also check this out. When I rev the car the pressure just goes to 3.5 and jumps back to 4.2 I posted a video
I'm not an expert on fuel systems but a 0.2 bar drop in fuel pressure just from the return lines not flowing enough sounds like a lot, especially if you haven't bypassed the FPCM. Have you bypassed the FPCM btw?
What size fuel lines ?
What pump ?
What’s a fpcm?
this is what the fuel pressure does plugging it in and out. It raises when you unplug it
38 minutes ago, Murray_Calavera said:
Lines are stock sized.
Pump is Walbro/Aeroflow/TI automotive 525 LPH.
Though so, 10psi change is not normal and sounds very restricted. What possessed you use one of these on stock lines ?!
For example our white 32 has the same 525lph with AN8 top hat fittings, AN8 supply and return lines with an FPR1200 using PWM.
Changes about 4 - 5 psi
Stock Nismo pump  stock reg on 5/16 lines changes about 3-4psi in my 33.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
    • Yep, this bit another local owner. I caught it before putting the transmission back into the car, what I noticed was the pressure plate fingers weren't flat and even. It's more obvious with the pull style clutch because the throwout bearing ring was visibly not flat once everything is put together. Nismo should really update their instructions to call out this specific detail. I'm not even sure the clutch as-shipped orients everything properly.
