Looks very nice  . . . however I have never see an impeller corrode out over time.
If you are using the correct coolant there should be minimal or no corrosion in the engine at all !
The bearings will probably wear out before the impeller has issues.
There might be an advantage if the pump is rebuildable as was done in dinosaur days of the past !
  • Like 2
https://www.sau.com.au/forums/topic/484657-water-pump/#findComment-7979167
If its going on an RB25/26 then you are better off getting the proper pump.  The RB30 one fits fine but has one less mounting bolt up near the top......and they always seem to leak in that area albeit after a few miles.  The proper RB 25/26 ones seem to hold tight longer IMO.
  • Like 1
https://www.sau.com.au/forums/topic/484657-water-pump/#findComment-7979329
I'll be install on a RB30 block.
Are you descriping the slotted hole?
https://www.sau.com.au/forums/topic/484657-water-pump/#findComment-7979332
3 minutes ago, Predator1 said:
When will yours be running? Keen to hear how your 9280 turns out.
It will be a ways away. I'm painting my car on top of waiting for parts all the time. I will definitely update when on the turbo when I get it running
https://www.sau.com.au/forums/topic/484657-water-pump/#findComment-7979723
2 hours ago, Predator1 said:
Nice man. Can I ask about your head? What mods etc? I hit a fkn brick wall on my setup, so keen to hear others running EFR on rb30's.
I got my head worked on by Mazworx out in Florida. I went with their stage 2.5 package. Cams are Kelford 182-SE.
https://www.sau.com.au/forums/topic/484657-water-pump/#findComment-7979761
Looks great !
I took a quick look at their web site and the price is up there in comparison to other quite well know brands.
But in saying that, that's a machined bronze impellers and certainly looks the goods.
Still got to ask if its re-buildable ?
  • Like 1
https://www.sau.com.au/forums/topic/484657-water-pump/#findComment-7979770
56 minutes ago, PLYNX said:
Looks great !
Overall its different. I figured I'd give it a try. If it's sucks then, i can at least say is not worth it and suggest an N1 or Reimax.
I forgot to ask about if it's rebuildable. I can only assume it is.
The price is a little higher but with the impeller material and machining I can see why.
https://www.sau.com.au/forums/topic/484657-water-pump/#findComment-7979776
How much was that WP? Just out of curiosity, what are the flow rates? I recently changed mine because Im a overly pedantic fkwit :D and decided to splash out on the Gr.A Reimax waterpump.. and it made a pretty good dent in the coolant temps.
  • Like 1
https://www.sau.com.au/forums/topic/484657-water-pump/#findComment-7979791
I paid $327USD
I dont know the flow rate. I can imagine its high considering the length of the blades. Id have to measure the impeller and math it out
I saw your thread about the cooling issues with your intercooler and hypertune lol.
https://www.sau.com.au/forums/topic/484657-water-pump/#findComment-7979792
IMG_2691.thumb.jpeg.b150048c2cc0cf6fc750b28a56f8e400.jpegIMG_2696.thumb.jpeg.2985f022aa79940fb72f13702f59f03a.jpeg
Yeah! Hence why I was wondering. Looks like it should flow better then OEM/GMB style pumps. Its similar to the one I have.
haha dam right about Hyperf*knshitTune. Honestly stay away from them. I should have gone with Plazmaman instead. At least they were straight up and honest when I asked them specific details.
Mind if I ask what specs of your head? Feel free to pm if you want to keep it low key. Id be happy to share mine, just trying to compare setups and understand why the f**k my turbos out of puff.
  • Like 1
https://www.sau.com.au/forums/topic/484657-water-pump/#findComment-7979793
Yes in theory the larger impeller should flow more. from reading around, the vortex style impeller should be better than the open style
I have been dealing with them since last Sept for a radiator/fan combo. Stilll waiting...
Head:
CNC ported
Supertech Intake Valves, +1mm
Supertech Inconel Exhaust Valves, +1mm
Supertech Bronze Valve Guides
Supertech Dual Spring Kit, 92/82lbs
Supertech Titanium Retainers
Supertech Valve Seals
Kelford 182-SE
I chose the keep the quench pad as I havent read anything solid around to remove them for a street car. removing the quench adds about 70cc
Edited by SLVRBAKSLPZ
  • Like 1
https://www.sau.com.au/forums/topic/484657-water-pump/#findComment-7979795
Head:
CNC ported
Kelford 182-SE
Why am I not surprised haha. Peter is such an absolute cock. False promises after another. I was on the verge of threatening him. My advice, steer clear of them at all costs. He LOVES to take money, and once youre paid up, communications just drop and you have to literally beg for updates, where you will get grumpy short replies.
Anyways, your head is similar to mine, what duration/lift? Im running 278/286 with around 10.8-11mm lift. Did they do a flow test pre/post porting? Mine flowed 300cfm post.. which is supposed to be quite a lot apparently.
  • Like 2
https://www.sau.com.au/forums/topic/484657-water-pump/#findComment-7979796
Yeah, Im not messing with them after this experience. I had to contact one of the fab guys on IG before pete sent me an "sorry we've been busy" email. The fab guy has been my POC for the last couple months. Now pending shipment.
274°-270°/280° | 10.55mm-10.50mm/10.50mm Valve Lift - 274°/270° split lobe intake, 280° exhaust. The head gets delivered today actually. I will see if it comes with e blueprint/flow sheet.
  • Like 1
https://www.sau.com.au/forums/topic/484657-water-pump/#findComment-7979824
    • See if you can thermal epoxy a heatsink or two onto it?
    • The other problem was one of those "oh shit we are going to die moments". Basically the high spec Q50s have a full electric steering rack, and the povo ones had a regular hydraulic rack with an electric pump.  So couple of laps into session 5 as I came into turn 2 (big run off now, happily), the dash turned into a christmas tree and the steering became super heavy and I went well off. I assumed it was a tyre failure so limped to the pits, but everything was OK. But....the master warning light was still on so I checked the DTCs and saw – C13E6 “Heat Protection”. Yes, that bloody steering rack computer sitting where the oil cooler should be has its own sensors and error logic, and decided I was using the steering wheel too much. I really appreciated the helpful information in the manual (my bold) POSSIBLE CAUSE • Continuing the overloading steering (Sports driving in the circuit etc,) “DATA MONITOR” >> “C/M TEMPERATURE”. The rise of steering force motor internal temperature caused the protection function to operate. This is not a system malfunction. INSPECTION END So, basically the electric motor in the steering rack got to 150c, and it decided to shut down without warning for my safety. Didn't feel safe. Short term I'll see if I can duct some air to that motor (the engine bay is sealed pretty tight). Long term, depending on how often this happens, I'll look into swapping the povo spec electric/hydraulic rack in. While the rack should be fine the power supply to the pump will be a pain and might be best to deal with it when I add a PDM.
    • And finally, 2 problems I really need to sort.  Firstly as Matt said the auto trans is not happy as it gets hot - I couldn't log the temps but the gauge showed 90o. On the first day I took it out back in Feb, because the coolant was getting hot I never got to any auto trans issues; but on this day by late session 3 and then really clearly in 4 and 5 as it got hotter it just would not shift up. You can hear the issue really clearly at 12:55 and 16:20 on the vid. So the good news is, literally this week Ecutek finally released tuning for the jatco 7 speed. I'll have a chat to Racebox and see what they can do electrically to keep it cooler and to get the gears, if anything. That will likely take some R&D and can only really happen on track as it never gets even warm with road use. I've also picked up some eye wateringly expensive Redline D6 ATF to try, it had the highest viscosity I could find at 100o so we will see if that helps (just waiting for some oil pan gaskets so I can change it properly). If neither of those work I need to remove the coolant/trans interwarmer and the radiator cooler and go to an external cooler....somewhere.....(goodbye washer reservoir?), and if that fails give up on this mad idea and wait for Nissan to release the manual 400R
    • So, what else.... Power. I don't know what it is making because I haven't done a post tune dyno run yet; I will when I get a chance. It was 240rwkw dead stock. Conclusion from the day....it does not need a single kw more until I sort some other stuff. It comes on so hard that I could hear the twin N1 turbos on the R32 crying, and I just can't use what it has around a tight track with the current setup. Brakes. They are perfect. Hit them hard all day and they never felt like having an issue; you can see in the video we were making ground on much lighter cars on better tyres under brakes. They are standard (red sport) calipers, standard size discs in DBA5000 2 piece, Winmax pads and Motul RBF600 fluid, all from Matty at Racebrakes Sydney. Keeping in mind the car is more powerful than my R32 and weighs 1780, he clearly knows his shit. Suspension. This is one of the first areas I need to change. It has electronically controlled dampers from factory, but everything is just way too soft for track work even on the hardest setting (it is nice when hustling on country roads though). In particular it rolls into oversteer mid corner and pitches too much under hard braking so it becomes unstable eg in the turn 1 kink I need to brake early, turn through the kink then brake again so I don't pirouette like an AE86. I need to get some decent shocks with matched springs and sway bars ASAP, even if it is just a v1 setup until I work out a proper race/rally setup later. Tyres. I am running Yoko A052 in 235/45/18 all round, because that was what I could get in approximately the right height on wheels I had in the shed (Rays/Nismo 18x8 off the old Leaf actually!). As track tyres they are pretty poor; I note GTSBoy recently posted a porker comparo video including them where they were about the same as AD09.....that is nothing like a top line track tyre. I'll start getting that sorted but realistically I should get proper sized wheels first (likely 9.5 +38 front and 11 +55 at the rear, so a custom order, and I can't rotate them like the R32), then work out what the best tyre option is. BTW on that, Targa Tas had gone to road tyres instead of semi slicks now so that is a whole other world of choices to sort. Diff. This is the other thing that urgently needs to be addressed. It left massive 1s out of the fish hook all day, even when I was trying not too (you can also hear it reving on the video, and see the RPM rising too fast compared to speed in the data). It has an open diff that Infiniti optimistically called a B-LSD for "Brake Limited Slip Diff". It does good straight line standing start 11s but it is woeful on the track. Nismo seem to make a 2 way for it.
    • Also, I logged some data from the ECU for each session (mostly oil pressures and various temps, but also speed, revs etc, can't believe I forgot accelerator position). The Ecutek data loads nicely to datazap, I got good data from sessions 2, 3 and 4: https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-2?log=0&data=7 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-3?log=0&data=6 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-4?log=0&data=6 Each session is cut into 3 files but loaded together, you can change between them in the top left. As the test sessions are mostly about the car, not me, I basically start by checking the oil pressure (good, or at least consistent all day). These have an electrically controlled oil pump which targets 25psi(!) at low load and 50 at high. I'm running a much thicker oil than recommended by nissan (they said 0w20, I'm running 10w40) so its a little higher. The main thing is that it doesn't drop too far, eg in the long left hand fish hook, or under brakes so I know I'm not getting oil surge. Good start. Then Oil and Coolant temp, plus intercooler and intake temps, like this: Keeping in mind ambient was about 5o at session 2, I'd say the oil temp is good. The coolant temp as OK but a big worry for hot days (it was getting to 110 back in Feb when it was 35o) so I need to keep addressing that. The water to air intercooler is working totally backwards where we get 5o air in the intake, squish/warm it in the turbos (unknown temp) then run it through the intercoolers which are say 65o max in this case, then the result is 20o air into the engine......the day was too atypical to draw a conclusion on that I think, in the united states of freedom they do a lot of upsizing the intercooler and heat exchanger cores to get those temps down but they were OK this time. The other interesting (but not concerning) part for me was the turbo speed vs boost graph: I circled an example from the main straight. With the tune boost peaks at around 18psi but it deliberately drops to about 14psi at redline because the turbos are tiny - they choke at high revs and just create more heat than power if you run them hard all the way. But you can also see the turbo speed at the same time; it raises from about 180,000rpm to 210,000rpm which the boost falls....imagine the turbine speed if they held 18psi to redline. The wastegates are electrically controlled so there is a heap of logic about boost target, actual boost, delta etc etc but it all seems to work well
