10 hours ago, Old man 32 GTR said:
R35 brakes for sure, that’s what I went for, for functional and looks, got my set with new oem rotors and dixel pads. 380mm rear and 390mm fronts, just me mindful it will limit your wheel options
Is a R35 GTR BBK still a 15K adventure? Are there cheaper options available for this as an aside? After looking for replacement pads for my kit - OEM BBK's for pad selection seem great blah blah blah.
Are there any other options?
I am going to buy a R33 upright, then will buy a set of those Z1 350Z to 370Z dog bones and see how much I need to mill off the dogbone to allow the Akebono caliper to fit on. Another option is to space out the dogbone, which might require more work.
I am not sure how thick the R34 GT-t upright caliper mounting tabs are, as this will influence how everything sits. The caliper essentially needs to sit at the same height as the original calipers.
(not my photo)
(not my photo)
HFM are currently working on a set of adapters for the 34. im sure some for 32's and 33's will be around the corner
https://www.instagram.com/p/Cs0bls6SrBY/?img_index=2
  • Like 1
Great! So this is a 355/350 kit with Nissan OEM bolting onto my R34 with all of the pad options that an OEM car can provide instead of Attakd/G4/Ksport (which are all slightly different) trying to cross reference fkin everything. With OEM dust boots.
In other words, exactly what I was hoping for!
Do the calipers cost 10K+ like R35 GTR ones?
If that's the case, I might as well not bother buying things to experiment with :D
If I were you, I would buy them now before every man and his dog does. A full set of Akebono can be had about the $1500 mark used.
  • Like 1
    • Ok I get you. But isn’t the butterfly intake a headache with the +T?  see this is my plan so far but please advise me into the right direction.  Nistune Ecu, 1000cc Bosch injectors, TD05 or TD06 Kinugawa turbo using stock rb25det exhuast manifold, walbro fuel pump unsure of model I think it’s 450/460, spitfire coils and sparks to suit and a R35 MAF sensor and boost sensor.    I was thinking maybe do a cheap eBay plenum $400-500 or try find a stock det neo intake. I think I’d port match it so it’s getting the full capacity but open to advice please.  Thanks
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
