Hi all, I have recently brought an engine (RB25DE) / manual gearbox (small box) from Facebook Market place for a good price which I will be putting into my R34 RB25DE sedan.
As you are probably aware the gearbox is an RB20 box which the N/A manuals had.
The problem that I'm having is with the boxes sensors. There are 3 ports on the box 2 of which are missing cables
I'm not sure if the speed sensor will fit my loom / it looks to be missing a cord? ( On purpose?) And its bracket is broken so a replacement is required. Would my 4 speed automatic one fit?
I have attached the photos below including speed sensor :)
Any help would be much appreciated 👍
Edited by RB25inside
Need to add tags
I'd start by seeing if your auto speed sensor does physically fit. If you go for something from another car it will need to have the same diff ratio to give you the right speed.
Also, both the neutral and reverse sensors seem to have their wires broken off too...whoever you go this from really looked after it. You probably don't need the neutral switch but without the reverse one you won't have working reverse lights
Thanks for the replys guys. I am yet to take out my auto gearbox but believe the R34 has two wires plug for the speed sensor? But currently the one in the box has 3 wires.
Does anyone know the exact model speed sensor I need?
I'll count the teeth on the sensor that it came with.
I can't imagine a 3-wire speed sensor. They're just (effectively) an electric motor that produces an AC voltage waveform as you spin them. 2 wires that go to the speedo. You should look at the R34 wiring diagrams to see if the auto speed sensor really is a 3 wire.
Yeah how interesting right! As I am in Australia maybe it was from a Commodore at some point? If I look up VL gearbox speed sensor it looks awful similar.
While searching this morning I found this https://vegaautosports.com/products/speedo-sensor-and-pinon-to-suit-nissan-silvia-s14-and-skyline-r33-n-a-gearboxes not sure if this would fit into my box seeming its an RB20 box of some sort. The images don't really show if there are any plugs. But yet again it shows Silvia parts in RB20 Boxes. What do you think?
I don't know enough about the CA/SR gearboxes. They are very similar to the small RB boxes, but as with all Nissan stuff, there are small and annoying differences everywhere you look.
I can say that there is no difference at all between an RB20 turbo and R33/4 NA box. Well, alright, again small differences. I'm pretty sure 3rd gear was a different ratio between R32 turbo and R34 NA boxen (I had both in my car). But the speedo drive (cable, for R32) just goes directly into the R33/4 boxes like it was made to, because it was.
So If that's the case and the R32 speed (Cable) sensor goes into the rb20 box would that mean the R33 sensor should fit into my rb20 box?
Yes, so long as we're talking about the RB20 turbo box and the R33 RB25DE NA box. I cannot promise you that the R32 NA box is the same as these though. It probably is, as again it is effectively the same sort of box as the CA/SR boxes, and almost the same as the 20DET box. They are definitely not all the exact same though. The 20DET box is stronger than the 20DE box, for example, even if it is only a little stronger.
Okay so I have done some R&D the RB25DE sensor has 21 teeth and is a lot longer then my model.
RB25DE sensor model (purple)codes are:
25010-79T01 – Sender
32743-71T21 – Gear / Cog
As you can see this is much larger then my speed sensor shown above. Further research has found that the S13 / SR20 / KA24DE sensors are the same size as the RB20 (R32) and still offer 21 teeth while supplying two output wires (As seen in red cog)
So I'm 99% sure it will fit into my box but the question is will it out put the correct voltage pattern??????
Well, the speedo sender is trying to work out road speed from the gearbox's output shaft speed...therefore the diff ratio (and tyre height) must be assumed in the speed sender. So, if your car/diff (r34 auto) matches the speed sender you are looking at it will be fine.
  • Thanks 1
Okay so correct me if I'm wrong my R34 is RC40 and according to this website it means my car is:
R34 GT – RB25DE – auto – 4.083
https://www.eatsleepboost.lt/tech-info/nissan-tech-info/nissan-r200-diff-ratios/
This website also lists the S13 diff ratios as the following:
S13 – KA24DE – USDM – manual/auto – R200/R200V – 4.083
S13 – CA18DE – JDM – r180 6 bolt – manual/auto – 4.363
S13 – CA18DET – EDM – manual/auto – R200/R200V – 3.916
S13 – CA18DET – ADM – manual/auto – 4.363
S13 – CA18DET – JDM – manual/auto – 4.363
S13 – SR20DE (ABS) – manual/auto – 4.111
S13 – SR20DET – manual – 4.111
S13 – SR20DET – auto – 3.916
PS13/RPS13 – SR20DE (ABS) – JDM – manual/auto – 4.083
PS13/RPS13 – SR20DET – JDM – manual – 4.083
PS13/RPS13 – SR20DET – JDM – auto – 3.916
So if my understanding is right I need a KA24DE USDM or a JDM version. Probably the KA24DE would be the easiest and safest bet to get?
    • They are, a good friend of mine bought one to replace his blow factory turbo, running a Toshi Tune reflash. Just use their supplied water/oil lines and you're good to go. At the time, they were like $900 delivered.
    • This is an option for 100% bolt on, the GCG high flow -  https://gcg.com.au/turbo-charger-upgrade-skyline-gtst-2iu-xtrgts-s1.html Also, I'm pretty sure hypergear does a high flow that is 100% bolt on, it just doesn't make as much power as their bigger high flows.  Even if you get a hypergear turbo that requires you to chance the intake piping, it is a really simple modification. It can be as simple as a piece of silicon hose and you pop a filter on the end. It doesn't have to be some crazy pie cut titanium work of art intake pipe.  If you have the ability to swap the turbo yourself, you would be able to sort the intake piping out.
    • Just as a thought, if it's in neutral, thats your drive line disconnect, not the clutch. Clutch slip at the dyno with pedal fully out, is actually adding a second disconnect. So it's not a clutch issue if you're in neutral. Just a bit of friction dragging the output around while in the air.
    • The HG high flow is excellent, and costs about the $$ you're talking about. But it, and probably every other highflow, uses a diffeent core than the original turo, and the original Hitatchi core is quite long. So, I think it is inevitable that there is likely no such thing as a highflow that just "bolts on" with no other effort required. And the same is likely true for HG's outright replacement "bolt on" turbos (the ATR things). And the same is likely true for anything similar from elsewhere. I have no idea if the cheap Chinese/Taiwanese complete turbos from eBay/Temu/etc are as bolt on as they claim. I mean, they claim the bolt onto the NAs as well as the turbos, and we know that can't be "bolt on". But it wouldn't matter because I'm not buying a $169 4 psi turbo for anything other than a paddock basher.
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
