hi there i got a HR34 and it stop start i dont know why
when i try to start the car it crunk but did not start and when i stop crucking it i get a sound from the trriger ( 3 or 4 tiking sound ) with a engine flashing
i change everything and look at the timming for the engine every thing ok
i got a haltech plug in ecu
this a video for what happening
Edited by blotan
https://www.sau.com.au/forums/topic/485216-rb25det-neo-wont-start/
There is nothing in the CAS that should be able to make ANY sound. It is a thin disc that spins through a gap in the sensor, which shines light through slots in the disc to count degrees of rotation. There is no contact between any moving parts in there.
So, I can only assume that the drive off the end of the exhaust cam has broken, or something equally horrible.
Take the CAS off and have a look. There should be an obvious match between the drive male and female on the cam end and the back of the CAS. Anything that is missing, smashed up/powdered or falls down into the timing cover when you pull the CAS is an obvious bad sign.
The fact that the ECU tells you there is nothing wrong is suspicious. Can you see it saying that it sees the home/reset signal when you check the software while cranking?
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
    • You just need a wheel alignment after, so just set them to the same as current and drive to the shop. As there are 2 upper links it may also be worth adding adjustable upper front links at the same time; these reduce bump steer when you move the camber (note that setting those correctly takes a lot longer as you have to recheck the camber at each length of the toe arm, through a range of movement, so you could just ignore that unless the handling becomes unpredictable)
    • I got adjustable after market rear camber arm to replace the stock one's because got sick of having to buy new rear tyres every few months. Can anyone please let me know what the best adjustment length would be. I don't have the old ones anymore to get measurements. I'm guessing the stock measurement minus a few mm would do it. Please any help on replacing them would be fantastic I've watched the YouTube clips but no-one talks about how long to set the camber arm to.
    • Heh. I copied the link to the video direct, instead of the thread I mentioned. But the video is the main value content anyway. Otherwise, yes, in Europe, surely you'd be expected to buy local. Being whichever flavour of Michelin, Continental or Pirelli suits your usage model.
