Anyone know anything about a r34 350z lsd diff conversion?.  I have 350z lsd conversion layin around and thought about chucking it in my r34 I got all the offset adapters but am having trouble figuring out on how to get a speedo reading. Any help would be appreciated thanks
(I have both speedo sensors from r34 and 350z)
https://www.sau.com.au/forums/topic/485572-r34-350z-lsd-conversion-speedo/
3 minutes ago, GTSBoy said:
R34 vehicle speed sensor is in the gearbag.
hey man nah I’m sure they get it from the diff like the s15 my speedo went out in the past and I just replaced the sensor in the diff and everything was working again
(idk if this helps but I got a HR34 sedan)
OK, that explains it. The auto NAs are not something that even enter my thinking 99.9% of the time.
If you put a small turbo box into it then you could use an appropriate speedo sender in that and connect to the dash. The caveat there is that I have no idea if the calibration of the dash would be even close to correct. It might not even work. I do not know how the diff mounted speed sender works, and there is every possibility that it is different to the signal generated from the gearbox mounted sensors.
I would suggest hooking an oscilloscope up to your speed signal from sender to dash and recording the waveform at some known speeds.
yea that might be an issue the sensor in the diff is for both abs and speedo same with the 350z diff except the 350z diff has 4pin connected while the r34 one is 2 pin.
One thing you may be able to leverage is the fact that the R34 N/A has the same setup as a S15.
The S15 also is a car that gets 350Z diff swapped, so they will also likely have this problem.
The caveat of course is it's possible the dash is different between the R34 NA and the S15, but the subframe/sensors/axles/diff setup are the same.
I can't remember now as it's been too long, but I don't generally think people need to swap dashes between the N/A dash and the turbo dash when they do things like change the gearbox out, turbo their car, manual swap it, it's just not something I've seen mentioned so this could be compatible.
  • Like 1
  • 1 month later...
Having seen a 350z diff swap I wouldn't do it, they don't really fit because the diff mounting ears are higher up the case and the diff sits very low in the sub frame.
I looked at it but am getting 3.5 gears from Neat instead.
Edited by Komdotkom
Put it in about 2weekz ago I haven’t heard anyone do it before but all the parts just fit right in the diff sits quite low and the diff ratio is pretty f**ked I thought I bought a 3.6 but I ended up with a 3.3 I believe😭
looking into finding something closer to the original ratio to the r34 diff (4.1)
also having trouble trying to get somewhere to get a speed reading as the r34 sedan gets the speedo reading and abs from the diff
update i did some test and think the diff has a 3.3 ratio i also took it out and readjusted the offset bushing on the subframe which made the diff sit higher about the same as the stock r200 r34 diff.  (P.S : you'll need an 18mm spacer fabricated from your driveshaft to diff flange as there is a gap i think it might be unnecessary for some skylines
I have a HR34 which is also a 4speed automatic which is now slower with the smaller ratio as the OG ratio is 3.9. ill see whether or not ill change the ratio after i do my manual swap. I am putting in a RB20det gearbox in it honestly hoping the gearing will be better if not ill probably steal a crown and pinion from a g37 or some with the 3.9 ratio
After some inspection it seems that the diff has a metal gear near the diff flange with the sensor slotting in a hole that hovers above it. I believe it is some sorta Hall effect sensor which reads the amount of rotations of the pinion to calculate the cars speed.
the 350z also uses this mechanism on the diff except it has it on either one of the diff flangers and 2 seperate speed sensors. I soldered the wires and i still have no reading.
might just go with the gps speedo at this stage haha
Yes, well, that wouldn't work even if the sensor was compatible, as the pulse rate would be all wrong.
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
