Whilst the brewery had good beer, I didn't rate the pork knuckle, the meat was good, but, there was no crackling, the skin was just thick and chewy
Will return at some stage for the beer, but, I will wash the beer down with chips
Another upsetting factor was.....no sauerkraut, I even asked the staff about it, none even knew what sauerkrauteven was, in what world do people serve pork knuckle without sauerkraut, they did serve apple slaw with it, which was nice, but.......#sauerkraut the world
  • Sad 1
https://www.sau.com.au/forums/topic/486007-nc-mx5/page/17/#findComment-8004380
Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be!
The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
https://www.sau.com.au/forums/topic/486007-nc-mx5/page/17/#findComment-8004385
I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there
Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
https://www.sau.com.au/forums/topic/486007-nc-mx5/page/17/#findComment-8004386
The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good.
I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
https://www.sau.com.au/forums/topic/486007-nc-mx5/page/17/#findComment-8004388
There was a great one on Victoria Rd in Gladesville too back in the day.
I can only assume GTSBoy is thinking of the mill up on the wollondilly, no restaurant there any more but they have restored the original steam engine on site and run it every few months, have an annual steampunk festival etc
@The Bogan, you came to the wrong town for restaurants. we have a few reasonable asian and indian options but the Paragon is as good as it gets otherwise. That brewery is apparently just opened, been meaning to give it a go some time. The Highlands have plenty of fancy options but I suspect you are more a hearty eater than fancy eater
  • Like 1
https://www.sau.com.au/forums/topic/486007-nc-mx5/page/17/#findComment-8004405
Definitely a hearty eater when we go out, I consider these meals my cheat day as I've been watching my calories in and calories out pretty hard since my little fun size stroke, I've gone from a fat boy of 89 Kg, I'm only 165cm tall/short, down to a almost semi lean 73 Kg over the last few years, I'm currently around 17% body fat which my doctor is very happy with, but, my goal is to slowly get down to and maintain 15%,so yeah, I want all of the protein, carbs, fats and sugars when I go out for a binge
https://www.sau.com.au/forums/topic/486007-nc-mx5/page/17/#findComment-8004406
Decided to upgrade my pressurised plastic coolant expansion tank for a fancy pants alloy version
The OEM versions can get brittle, even the new plastic one I got when I first got the car is a starting to show signs of "stress"
I wasn't cheap, but it is basically unbreakable
  • Like 3
https://www.sau.com.au/forums/topic/486007-nc-mx5/page/17/#findComment-8004606
Looks fancy
But after having a look, prior to its installation, I noticed that the yellow looking power steering reservoir would look crap next to this
So I have this incoming.....
Much cheaper than the Moroso and has great reviews (yeap, it's a Moroso knock off)
  • Like 2
https://www.sau.com.au/forums/topic/486007-nc-mx5/page/17/#findComment-8004730
22 minutes ago, soviet_merlin said:
Looks great, but I'm always concerned that it makes it difficult impossible to see what level the fluids are at. Am I overthinking this?
Yes, overthinking.
Many PS reserviors are completely opaque. Our Skyline ones, for example. Have to remove lid, peak inside, swirl the dipstick, try to remember how to read it, etc etc. Normal.
Radiator overflows are often sufficiently opaque and scunged up that you can't see the true level inside anyway, and have to open and have a peak. Besides which, I replaced the (massively expensive, even back then) plastic overflow in my Alfa GTV, back in the '90s with a stainless one that I had a good fabricator make up to be dimensionally same-same, that looks remarkably similar to the Bogan's Moroso one above, and I never suffered any particular paranoia that I didn't know how much coolant was in it.
https://www.sau.com.au/forums/topic/486007-nc-mx5/page/17/#findComment-8004732
1 hour ago, GTSBoy said:
Yes, overthinking.
To back this up, I'm always looking on the outside, seeing the level, and then opening it up anyway, as I'm worried the level I've looked at, is more so a scunge line. Then you end up dipping your damn finger in it too depending on the type of tank you're looking at just to make sure I'm not going insane.
PS, Mark, polish up the none moroso one a bit and then give it a clear coat. The Moroso one looks to be way shiner (not mirror polished, just shinier) and it'll still look weird with the two different alloys beside each other.
Either that, or Id probably paint them a flat black...
  • Haha 1
https://www.sau.com.au/forums/topic/486007-nc-mx5/page/17/#findComment-8004735
Wrinkle black will be a thing for both
https://www.sau.com.au/forums/topic/486007-nc-mx5/page/17/#findComment-8004737
4 hours ago, soviet_merlin said:
Looks great, but I'm always concerned that it makes it difficult to see what level the fluids are at. Am I overthinking this?
4 hours ago, GTSBoy said:
Yes, overthinking.
The alloy coolant reservoir has a sight glass, so as long as I can see coolant in the sight glass it's GTG, as for PS, it isn't anything catastrophic if it gets low, and as it hasn't lost a drop since I have owned the car I cannot see it being an issue, even after putting the "big block" 2.5 in....LOL
The only time it gets slightly messy is at oil changes, as the oil filter sits above the frame, and I need to use a plastic bottle with its bottom cut off to catch the flow when loosening the filter
  • Like 1
https://www.sau.com.au/forums/topic/486007-nc-mx5/page/17/#findComment-8004739
    • Please also tow another Skyline soon too haha
    • Wild idea, can you do half and half? Lol.
    • I’ve dedicated my career to the car transport industry. Over the years, I’ve worked across every part of the process — from arranging pickups and managing drivers, to ensuring vehicles are delivered safely and on time. I know how much people value their cars, whether it’s a family vehicle, a dealership delivery, or a classic car, and I make it my responsibility to treat every transport job with care and transparency. As an independent member of the Car Transport Association, I represent not just my own work, but also the broader interests of customers and carriers. I believe in raising standards across the industry — better safety checks, clearer condition reporting, fairer pricing, and honest communication. My approach is practical: solve problems before they happen, make processes easier for drivers and customers, and always keep the focus on reliability. What sets me apart is my commitment to clear communication. I provide updates, photos, and accurate delivery times so that customers know exactly where they stand. My goal is simple: safe, transparent, and trustworthy vehicle transport, every single time. If you’re looking for a partner in car transport who values accountability and professionalism, I’d be glad to connect.
    • Because sometimes I do dumb shit and because I kept thinking about 6.6kWh worth of PVs wouldn't be fully enough if I'm consuming during the day as well as charging. So I did a thing, added another 5kW of PVs lol. Since there's a spare MPPT port, why the fk not?
