Anywhere i can take my car in a hurry to get more camber wound into the front, preferably around Cheltenham area. Already have the bits on the acr, just a matter of changing the stiings...ideally would liek someone with a clue so that they can also change the castor toe etc to make the car work its semi slicks properly.
I usually use Centrline but they are too far away and too busy at the moment to squeeze my car in at the last minute...
Any help would be appreciated.
https://www.sau.com.au/forums/topic/49189-good-susp-place-around-cheltenham/
Not sure if they do suspension or not but you could try:
SOUTH EASTERN TYRES & AUTO CENTRE
spacer.gifspacer.gifspacer.gifspacer.gifU 10/ 50 Westall Rd Springvale 3171
(03) 9540 3766 spacer.gifspacer.gifspacer.gifSpringvale Fax 3171
(03) 9561 5159
They are pretty good for alignments n stuff - Richard is the guy to talk to - give them a call!
Hi Roy try this place
- I had some good reports from people on Skylines about here
Advantage Suspension Pty Ltd
Fact 4/ 1 Winston Crt Moorabbin 3189 (03) 9555 2633
Roy... Why Cheltenham? {spelling}  > TRUTRAK in Leveson Street, North Melbourne now their stuff. I'm sure they have something to do with that GTR that races at the WRX meetings.
LOL cause my caer is still at Ice and im going to PI on the weekend...and it doesnt look like ill be pickign my car up to tomorrow, so with work etc etc it neds to be close to them...
Bugger it ill ust stiffen up the swaybars and hope that stops the outside shoulder of the front tyres from gettign too hot and blistering...im actually kinda hoping the track is cold and damp so that the grip level is low and i dotn kill expensive tyres :P
By the time i got my sh1t together i was lucky to make it to Phillip Island, so didnt have time to get a wheel alignment...as i wont be pushed for time next tiem around im going to stick with Centreline, i was very, very happy with them the two times i used them
  • 5 months later...
Sorry to drag up an old thread. But I had a recent experience with this place which was interesting...
Frank (owner of the white 33R) is good mates with Ralph (owner of TruTrak). Ralph has done a lot of the work on that GTR.
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
    • Any idea where I can get genuine MAF apart from used ones? I can't find any only for GTRs and unfortunately that price is not in my budget 🤣 I might gap my plugs down and put my splitfires in, they were only in for a year or so before I started the rebuild
