Hi all,
I copped some flack on another thread because of my intention to do an RB conversion to my HR30 Paul Newman.
What are the thoughts on a sort of stock looking 3029cc L Series in my PNV.
All the purists accept that on a power upgrade?????
https://www.sau.com.au/forums/topic/49228-r30-purists/
  • Replies 50
Grumpy old turd alert.
I'll give you my honest suggestion and that is to set your old shitter on fire. Can't say I own a classic? You don't know what I own you ignorant fool. I'd take a DR30 any day over that. HR30's were built for hitting kerbslike this
https://www.sau.com.au/forums/topic/49228-r30-purists/#findComment-984803
I'll give you my honest suggestion and that is to set your old shitter on fire. Can't say I own a classic? You don't know what I own you ignorant fool. I'd take a DR30 any day over that. [pisstake]HR30's are only good for hitting kerbs like this.[/pisstake]
https://www.sau.com.au/forums/topic/49228-r30-purists/#findComment-984804
HR30 PNE is hardly a shitter its like the brock edition of a commo (sorry to have to use that foul language).
I own a few cars of which one is powered by an RB25DET and the other a modified L28E.. guess which ones more fun to drive? thats right the MR30!! that L series growl and the unadulterated power is insane, who cares if its only a 2 valve, single cam, non cross flow engine? they can still make power and are a very good engine... and i am sure Ghostriders intentions for the 3.1L are not going to be shabby.
https://www.sau.com.au/forums/topic/49228-r30-purists/#findComment-985051
Dear oh dear,this thread got off to an angry start! ;)
Ghostrider,in anohter thread didn't you say you had just completed the built of an RB25/30?
If you've finished this engine,I'd say stick to your original plan and use it.Much more cost effective! :) I think it'd have to be more "street friendly" than an angry L too. Although a 3L L's big stroke could bring a T51R on boost nice and early! :D
Your car....it's up to you!
https://www.sau.com.au/forums/topic/49228-r30-purists/#findComment-985323
go the rb, but dont modify any original parts....use 2nd hand xmembers to chop, or make new ones, that way you can return it to standard...on the other hand, unless its completely stock at the moment, ie orig motor and brakes and such, it doesnt matter what you do to it cos it is no longer original anyways...
hell i dont know i love the old L series too.....supercharged 3.1 litre Lseries......oh god yes!
https://www.sau.com.au/forums/topic/49228-r30-purists/#findComment-985437
To RSX, Turbo of coarse, probably a T04R or the GT35/40 I bought for the RB. The problems I spoke of are currently under control, these alternative medicine guys can be brilliant.
OHR30T, Yes the RB is finished, but thought I might shelve it for a while, as the 3L L Series sounds awesome, just think, No engineers report needed, no cat, just get a blue slip and go, as by chance, it will still be carrying the L20A engine number. Let our RTA & police have fun with that.
https://www.sau.com.au/forums/topic/49228-r30-purists/#findComment-985595
What can I say?????
Listen to the masses, you appear to be out numbered in your views.
As you have the numbers covered, we won't know for sure, but as it has WA plates, DID YOU HAVE A BAD DAY AT THE DRIFTING???????
As for HR's on drift, maybe you should look at some of the R33's after they come unglued at the drift meets, even the japs have mishaps occassionally, just look at the videos from HPI Magazine.
For your info, DR, HR & MR Skylines are basically identical and mine has all the new hi tech bits, like coil over suspension, DR front & rear brakes, Cusco LSD, fully adjustable front & rear suspension and IF I choose to build this 3L stroker, I think it might be quicker than your GTS25t, now wouldn't that be embarrassing.
https://www.sau.com.au/forums/topic/49228-r30-purists/#findComment-985648
i think b005t would smoke you
you asked for an opinion, now dont cry if its not what you wanted to hear, or where you just after someone to justify a choice you have made?
l series engines are buckets of shit. but hey, do whatever you like.
That's an interesting thought.
On paper, I can produce at least 250rwkw @ 15psi from the L Series motor and my HR weighs just 1100kg. That would mean his R33 would have to have 300rwkw to just equal the same power to weight ratio, not to mention the enormous torque the 3.1 would produce.
You guys think the RB's are the be all and end all of engines, maybe I should just go for it and see how I compare on the dyno, you might be embarrassed as well.
It would be interesting if my "bucket of shit" out performs you eh!!!!!
I have built an RB30/25 DET and think I can equal or better the output with an L series of similar capacity. After all, absolute HP means stuff all if you can't get it to the ground successfully.
A mate has an L28ET running on straight LPG and point to point, he was faster with 145rwkw than he is now with 180, as now wheel spin out of corners is a problem.
https://www.sau.com.au/forums/topic/49228-r30-purists/#findComment-985845
the old L series are built tough!!
i know of many that seem to go on forever if looked after.. i have 2 bluebirds with L20B's at home and one has done 350,000+ kms (speedo stopped) and thats my daily driver it still goes really well and doesn't hessitate to start.. my dad even said to me he was surprised it didn't blow any smoke! the other one blew a head gasket due to a broken waterline which ran through the inlet manifold. $30 head gasket and she'll be good!
and my L28 snaps the tacho round quicker than the RB does!
why not go twin turbo blow through mikuni's?? haha has anyone else seen that S14 in japan with the L31 setup like that?
https://www.sau.com.au/forums/topic/49228-r30-purists/#findComment-988110
Haha,the "up yours RTA" value alone would make it worth doing! :D
And is it some people don't like old engines,or is it old Skylines? :)
https://www.sau.com.au/forums/topic/49228-r30-purists/#findComment-988855
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
