Official SAU Dyno Day V.2 Review Thread ***PICS*** v.56kdie
Well today saw the running of the second official dyno day at Unique Autosports dyno room in Castle Hill.
Though the day started slow with many people enjoying a Saturday sleep in, the carpark began to pack rapidly with a huge assortment of skylines and other high performance cars.
Congratulations must go to the individual class winners who were up against some stiff competition.
Results are listed below:
Award winners
Top RB20DET standard turbo - Silver GTS-T (R32 GTS-T) 150.6 Kw
Runnerup RB20DET standard turbo - Kinks (R31 w/ RB20DET) 144.5 Kw
Note: There were no modified turbo RB20DET's in attendance so a runnerup category for standard turbo was put in its place.
Top RB25DET standard turbo - R33vit (R33 GTS-T) 197.6 Kw
Top RB25DET modified turbo - B-Man (R33 GTS-T) 327.9 Kw
Top RB26DETT/RB30 standard turbos - Dave (R32 GTR) 249.5 Kw
Top RB26DETT/RB30 modified turbos - Antonio (RB30 Powered R33 GTS-T) 319.5 Kw
Zoom Magazine Encouragement award - Wilch (R33 GTS-T Series 2)
Overall competitor summary:
R33 GTS-T
B-Man - 327.9 Kw
Antonio - 319.6 Kw
Jimbo - 215.1 Kw
Sparki_D - 215 Kw
R33vit - 197.6 Kw
Goldrays - 181.6 Kw
Scott - 180.2 Kw
Ash - 173.0 Kw
Wilch - 166.9 Kw
Neil - 159.8 Kw
Eden - 158.3 Kw
R32 GTS-T
Silver GTS-T - 150.6 Kw
Cereal_Killer - 137.8 Kw
GTR
CNG - 301.3 Kw
Dave - 283 Kw
GTR032 - 188.6 Kw
Misc Entries
Grant - Soarer - 263.2 Kw
Andrew - Supra Twin Turbo - 246.2 Kw
Stewart - E46 M3 - 183.9 Kw
Haroon - S13 Silvia - 158.6 Kw
Kel - 350z - 156.9 Kw
Kinks - R31/RB20DET - 144.5 Kw
Sean - Supra Non-Turbo - 111.4 Kw
Carlo - Supercharged MR2 - 87.2 Kw
Chris - Datsun 240z - 67 Kw
Duncan - Datsun 200B - 49.7 Kw
Thankyou to all of you who attended today for making it a truely great day for all!
  • Replies 74
good day
did 321 GO have a turn?
and whos posting up photos???????????????????????????????????????????
sure did. Andrew made 178rwkw if memory serves me correctly.
I'm really disappointed with my dismal dyno effort. I have no idea why it was so low. I made 131.7rwkw previous with just a 3" dump / front pipe. Now with a full 3" including high flow cat, front mount and pod filter I managed a shocking 137.8. Very confused. :(
congrats to BMan for the highest figure of the day.
Yep Andrew's 321GO RB20 R32 GTS-T made 178rwkw with E Boost set at 15psi standard RB25 turbo, FMIC and full 3 inch exh. Also Dave's GTR who won RB26 stock turbo went back on dyno last and sorted out boost controller and made 280 somethingrwkw. Yes it was a big day and thanks to SAU gang for the biggest ever Dyno Day we have had. Thanks Uncle Nick and Carlo. Lots of good pics including that immaculate purple GTR.
PS. I had my third V drink in my life. Hope I can sleep tonight. I think I might be dreamin Skylines.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
