Sounds like you guys had a great time out there, and well done for coming top of the class :P
Now....I'll be down there from Monday until end of October, so I expect you all to
1) Organise a track day at each Vic track before then
2) Let me know where I can hire a cheap mx5/mrs/mgf etc etc
  • Replies 218
Adz,
You have done very well mate, congrats.
I was following you for a while and you were driving pretty smooth.
Ferni,
To answer your question from the other thread, my oil temp was 100 degrees. Do not worry too much about the guides around the cooler core, but get some vents happenning in your guard lining to circulate the air.
Chris were having highish oil temps as well and he drilled some holes on the lining as a temporary fix. I forgot to ask him how much of a difference it made, but he will let us know when he signs in.
My corner speeds were comparatively lower than everyone else, which fully explains the slower lap times. It was probably the mixture of driver and rubber and there is a lot improve on both counts.
Snwoman,
That is one hot pic, but Geoff is definitely sucking it in. :P
Cheers mate, you were pretty good for street tyres too. Did you like my drift style show on corner 5? Didn't expect to see you facing towards me when I came round on the next lap! Thats what you get for trying to keep up with a GT-40 on slicks! :P Mind you later on Semi's I had a moment, managed to floor it and bring it round though.
Did you mean turn 6...? Not much of a drift action was happenning, you were mostly spinning them on a straight line. A lot of smoke though, the girls thought someone blew up. :D
You were too slow anyway, so i took you over. :D
Snowman,
You are soft and sexy and smell tough with a whiff of petrol scent. :bahaha:
Chris told me that his temps dropped from about 120 on sat to about 110 on sun with the holes in the wheel guard inner, and he was driving harder on the sun.
Bingo Andrew, there is the next mod you have to perform before the next track day.
If you are eager enough, you can manufacture some sort of a guide around the core as well. Here is what my HKS one look like :
It's in two pieces and bolted together.
ahhh i didn't realise there were 2 peices, i was just thinking it was the left (inside) peice... shouldn't be to hard to measure up and get made, but first i would like to do what you have done with the gtst guard inner
...and there she sat all day, all dressed up and no date :(
The boys discuss the Wallabies disappointing Sat night performance :(
I was happy to throw the tyres on everyones cars, as the only thing i could really salvage from the weekend was seeing the big smiles of others as they jumped out of their cars :) ...its the only thing that kept me going. Does Geoff ever stop smiling :D
Forget lap times and sticky rubber, who didnt have an off? You should be ashamed :flamed: If you dont spin you aint try'n :D ...
Had a couple of big moments in the wet with the tail wagging the dog, but I caught them...kinda. No offs or full spins. I'm smiling just thinking about it :)
The ability of the track rubber allows so much more confidence and suddenly the race cars were not pulling anything in the turns, so were slaughtered on the straights.
Talked to the guy with the GT Falcon after the event and he'd had a good day too but was a bit put out by getting done by skylines. Quote "And how would sir like his ass handed to him today"
Troy - check out the photo of Andrew, Geoff and Emre (posted above) - i dont see much of a smile there - although it must be the only minute of the whole weekend that he wasn't smiling.
What can we say - Geoff is just a happy guy
...and more.
Emre - thanks for the info on the oil cooler. Was at least 10-15 degrees cooler with those holes I made.
Andrew - i'm going to have to sabotage your car if I cant beat you soon....
Troy - get your biatch back on the road. I wanna see that Geoff style grin light up on your face.
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
