  • Replies 41
i ordered mine yesterday if u want the AA11AA style u have to get the coloured ones, which cut me cause i only wanted the yellow ones but anyhow, its $50 once off then $130 a yr, u can't get the AA11AA ones custom, no matter what u do
what plates did u order?
I called up the RTA as soon as I heard the new style were out. At the moment the only way you can get a custom AA77AA plate is if you spend the $400 (or whatever it is) for full custom plates.
They didn't give me a date when I asked when you'd be able to personalise these plates.
so if i bought them now i'd only pay $50 and then $130 when i have to rego my car??? or is it $180 now and then an extra $130 then? :confused:
i think you pay 50 now. then when u pick them up it depends how much rego you have left. say u have 6 months left then you would pay half the 130
Sweet :P
I'm surprised it wasn't taken, although I guess there aren't many N/A enthusiasts to snatch it up. Do you think a person with a turbo would consider purchasing that plate at a future date?
Also, now I don't need to get the other plate I was going to get - NOT.A33 :P
so did u pay $180 upfront???? or just $50???
    • Thanks man, I appreciate that. I'll keep it in mind going forward, important to know.
    • I strongly recommend anyone playing with cars chasing anything electric, get a basic understanding of using a DMM, and about 12V DC systems. They're REALLY easy, you only need to know V=IR and how to apply it, and you can work out what your readings should be doing. For a simple check on a light bulb, you're looking for 12V at the positive to the light, a near zero resistance to ground, and then for a small resistance across the globe when unplugged. If one of those values isn't right, you won't get what you need. Now if they're all okay,and you then plug the light in, and it still won't work, you now do a voltage check across the globe positive to negative. It should effectively read full battery voltage. If it's not, especially if it's quite low, the age old V=IR starts to be able to be thought about, you now know though, for the current flowing, there isn't much voltage for the given resistance, but the rest of that V has to be dropping somewhere else. So now do a voltage check from ground of globe, to ground of car, then do voltage check from positive of battery, to positive of the light connector. Things like a high resistance in a wire/join will start to "steal" voltage on you. So now step back through which ever wire, until you find the voltage drop is non existent, you're now before what ever is steal your voltage for example.   There's plenty of YouTube videos, but really worth understanding some V=IR, and doing some even theoretical numbers to start to understand it. Then you'll know what the DMM is telling you.
    • Is Jackie home by Friday?
    • Item 10: Tech Edge wideband sensor interface and display. You’ll need to buy a new sensor. $150. Item 11: part of a Willians 5 point harness. $40 Item 12: OS88 gear display. No need for it now, my PPG sequential came with one. $30
